You need to remove all the conflicting repositories first as you have used the "qrepoadd" command. Run in terminal:
$ /etc/apt/sources.list.d/
$ sudo qreporm q4os-mxtools
$ qrepolist
and post back the output.
After the installation of mx-tools plasma, I can boot from Q4os Andromeda
But then I see the debian log screen and I am in the debian system. What I must do next?
To message #26
/etc/apt/sources.list.d/ bash: /etc/apt/sources.list.d/: Ist ein Verzeichnis
sudo qreporm q4os-mxtools Not removed as not present.
qrepolist
deb http://deb.debian.org/debian/ trixie main contrib non-free non-free-firmware
deb http://security.debian.org/debian-security/ trixie-security main contrib non-free non-free-firmware
deb http://deb.debian.org/debian/ trixie-updates main contrib non-free non-free-firmware
deb http://q4os.org/q4repo/ q4os-6-0-cn main
deb http://mirrors.rit.edu/mxlinux/mx-packages/mx/repo/ trixie main non-free ahs
deb https://q4os.sourceforge.io/qexarepo/mxtools/ trixie-mxtools-cn main
By the way how is the shortcut for shutdown or reeboot in debian?
You need to remove mx-tools repository from /etc/apt/soutces.list.d/ , then you install from the .qsi again.
Now run:
$ ls /etc/apt/sources.list.d/
to #20: cd /etc/apt/sources.list.d$
ls output 10_q4os.sources mx.list mxrepo2.sources
sudo rm 10_q4os.sources
sudo rm mx.list
sudo rm mxrepo2.sources
setup_q4os-mxtools-plasma_5.3-a1.qsu Output: MX-Tools is already installed so cancelling installation
What shall I do next?
Problem solved. bI installed Zorin Os instead.
If you would want to stay true to Q4OS, we can recommend installing Quarkos https://quark-os.sourceforge.io/ , as it is based on Ubuntu, just like Zorin. In anyway, good luck ![]()
