#1 2025-11-18 16:15
[Closed] KeePassXC theme problem
This issue more likely Trinity related, but still I decided to write about it here first.
I have Q4OS Andromeda Trinity installed.
System:
  Kernel: 6.12.57+deb13-amd64 arch: x86_64 bits: 64
  Desktop: TDE (Trinity) v: R14.1.5 Distro: Q4OS 6.3.1-deb13u1
Machine:
  Type: Desktop Mobo: Gigabyte model: G41M-Combo v: x.x
    serial: <superuser required> BIOS: Award v: FB date: 10/25/2012
CPU:
  Info: quad core model: Intel Core2 Quad Q9550 bits: 64 type: MCP cache:
    L2: 12 MiB
  Speed (MHz): avg: 2000 min/max: 2000/2834 cores: 1: 2000 2: 2000 3: 2000
    4: 2000
Graphics:
  Device-1: NVIDIA GK208B [GeForce GT 710] driver: nouveau v: kernel
  Display: x11 server: X.Org v: 21.1.16 driver: X: loaded: N/A
    unloaded: fbdev,modesetting,vesa dri: nouveau gpu: nouveau resolution: N/A
  API: EGL v: 1.5 drivers: nouveau,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.0.7-2 renderer: NV106
  API: Vulkan v: 1.4.309 drivers: llvmpipe surfaces: xcb,xlib
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo x11: xdriinfo,
    xdpyinfo, xprop, xrandr
Audio:
  Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
  Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel
  API: ALSA v: k6.12.57+deb13-amd64 status: kernel-api
  Server-1: aRts v: 1.5.10 status: active
  Server-2: PipeWire v: 1.4.2 status: active
Network:
  Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet driver: atl1c
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 232.89 GiB used: 59.7 GiB (25.6%)
  ID-1: /dev/sda vendor: Crucial model: CT250MX500SSD1 size: 232.89 GiB
Partition:
  ID-1: / size: 219.88 GiB used: 59.7 GiB (27.2%) fs: ext4 dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 8.42 GiB used: 0 KiB (0.0%)
    dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 40.0 C mobo: N/A gpu: nouveau temp: 33.0 C
  Fan Speeds (rpm): cpu: 760 fan-2: 1254
Info:
  Memory: total: 4 GiB available: 3.83 GiB used: 1.3 GiB (34.0%)
  Processes: 224 Uptime: 31m Shell: Bash inxi: 3.3.38
denis@g41m-andromeda:~$
I have installed KeePassXC from Debian repository using apt install keepassxc.
I have theming issue in this application.
In KeePassXC I have chosen the dark theme (because I like it). The theme works correctly. But, if I open KeePassXC and after that a TDE file manager Konqueror, the KeePassXC theme becomes broken.
Please watch video: https://drive.google.com/file/d/1CwYKZ3 … sp=sharing
Is it any way to avoid or workaround this issue?
#2 2025-11-18 17:43
Re: [Closed] KeePassXC theme problem
This looks to be Q4OS bug. You can workaround it editing "/opt/trinity/env/50_q4loginscr01.sh" file and comment out "QT_QPA_PLATFORMTHEME" line. We will investigate further and start to work on a fix.
#3 2025-11-19 11:44
Thank you Q4OS Team! Now KeePassXC theme works as expected. I will wait for a fix, because KeePassXC is an important program for me. I do not want to use any proprietary password managers such as NordPass or 1Password.
Also, I do not want to use Flatpak, because it consumes a lot of disk space, works slower and it has bad font rendering.
Update: For those, who will consider to use KeePassXC too, I suggest to install PfP: Pain-free Passwords NOT Legacy! browser extension. It will simplify typing your logins and passwords for websites.
#4 2025-12-03 15:42
This bug will be resolved in the upcoming Q4OS-5 and Q4OS-6 releases.
#5 2025-12-05 10:19
This issue is now fixed within the most recent Q4OS 6.4 release.
