#1 2025-11-07 22:29
Germ
[SOLVED] MX-Tools will not install on Q4OS 6.1
Downloaded the .qsi file for the q4os mx tools and it exits with this error when trying to install:
Simulation not successful, sorry, I cannot install now.
Cleaning and canceling ...
#2 2025-11-08 07:11
Re: [SOLVED] MX-Tools will not install on Q4OS 6.1
q4osteam has already responded, see https://www.q4os.org/forum/viewtopic.php?id=5683
#3 2025-11-08 13:19
MX tools for Q4OS 6 already work, so this is a bug.
@Germ
So we would need the following info to track down the issue:
- What desktop are you using, Plasma, Trinity, other ?
- Specify the .qsi file you downloaded
- Run in terminal and post back the output:
$ qrepolist
- Provide the install log "$HOME/.appsetup2/log/setup-mxtools-xxx.log"
#4 2025-11-08 15:05
Germ
Plasma desktop
setup_q4os-mxtools-plasma_5.3-a1.qsi
In terminal I get "permission denied"  as user and as root.
install log:
Calculating progress ...
Testing Internet connection ...
Testing Internet connection ... OK
Extracting archive ...
Extracting archive ... Done
Checking package system ...
Reading package lists... 100%
Reading package lists... Done
Building dependency tree... 50%
Reading state information... 0%
Verified ... OK
Autofix not needed ... OK
Waiting to complete current operation ... Done
Adding security keys ...
Adding security keys ... OK
Preparing installation files ...
Preparing installation files ... OK
Partial update sw database ...
0% [Working]
0% [Connecting to q4os.sourceforge.io]
0% [Waiting for headers]
Get:1 https://q4os.sourceforge.io/qexarepo/s4-snapshot trixie-s4-snapshot-cn InRelease [2,521 B]
0% [1 InRelease 2,521 B/2,521 B 100%]
68% [Working]
Get:2 https://q4os.sourceforge.io/qexarepo/s4-snapshot trixie-s4-snapshot-cn/main amd64 Packages [1,568 B]
98% [2 Packages 1,568 B/1,568 B 100%]
98% [Working]
98% [2 Packages store 0 B]
100% [Working]
Fetched 4,089 B in 15s (267 B/s)
Reading package lists... 5%
Partial update sw database ... Done
Testing installation ...
Reading package lists... 98%
The following packages were automatically installed and are no longer required:
chromium-common chromium-sandbox
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
calamares calamares-settings-debian covix-libs cracklib-runtime cryptsetup
cryptsetup-bin libburn4t64 libcrack2 libisoburn1t64 libisofs6t64 libjte2
libpwquality-common libpwquality1 libyaml-cpp0.8 menu s4-iso-template
s4-remaster s4-snapshot squashfs-tools syslinux-utils whois xorriso
Suggested packages:
cryptsetup-initramfs menu-l10n libcrypt-passwdmd5-perl xorriso-tcltk jigit
cdck
Recommended packages:
localize-repo
s4-remaster s4-snapshot s4-snapshot-extq squashfs-tools syslinux-utils whois
xorriso
0 upgraded, 23 newly installed, 0 to remove and 0 not upgraded.
Inst s4-iso-template (25.9.01mx25.1301 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [amd64])
Inst covix-libs (0.8.14+10mx25.1301 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [all])
Inst whois (5.6.3 Debian:13.1/stable [amd64])
Inst s4-remaster (25.06.02mx25.1301 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [all])
Inst squashfs-tools (1:4.6.1-1 Debian:13.1/stable [amd64])
Inst syslinux-utils (3:6.04~git20190206.bf6db5b4+dfsg1-3.1 Debian:13.1/stable [amd64])
Inst libburn4t64 (1.5.6-1.1+b1 Debian:13.1/stable [amd64])
Inst libjte2 (1.22-4+b2 Debian:13.1/stable [amd64])
Inst libisofs6t64 (1.5.6.pl01-1.1+b1 Debian:13.1/stable [amd64])
Inst libisoburn1t64 (1.5.6-1.2+b1 Debian:13.1/stable [amd64])
Inst xorriso (1.5.6-1.2+b1 Debian:13.1/stable [amd64])
Inst s4-snapshot (25.09.2.1301 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [amd64])
Conf s4-iso-template (25.9.01mx25.1301 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [amd64])
Conf covix-libs (0.8.14+10mx25.1301 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [all])
Conf whois (5.6.3 Debian:13.1/stable [amd64])
Conf s4-remaster (25.06.02mx25.1301 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [all])
Conf squashfs-tools (1:4.6.1-1 Debian:13.1/stable [amd64])
Conf syslinux-utils (3:6.04~git20190206.bf6db5b4+dfsg1-3.1 Debian:13.1/stable [amd64])
Conf libburn4t64 (1.5.6-1.1+b1 Debian:13.1/stable [amd64])
Conf libjte2 (1.22-4+b2 Debian:13.1/stable [amd64])
Conf libisofs6t64 (1.5.6.pl01-1.1+b1 Debian:13.1/stable [amd64])
Conf libisoburn1t64 (1.5.6-1.2+b1 Debian:13.1/stable [amd64])
Conf xorriso (1.5.6-1.2+b1 Debian:13.1/stable [amd64])
Conf s4-snapshot (25.09.2.1301 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [amd64])
Inst s4-snapshot-extq (1.1-a1 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [amd64])
Inst libpwquality-common (1.4.5-5 Debian:13.1/stable [all])
Inst libcrack2 (2.9.6-5.2+b1 Debian:13.1/stable [amd64])
Inst libpwquality1 (1.4.5-5 Debian:13.1/stable [amd64])
Inst libyaml-cpp0.8 (0.8.0+dfsg-7 Debian:13.1/stable [amd64])
Inst calamares (3.3.14-1 Debian:13.1/stable [amd64])
Inst cryptsetup-bin (2:2.7.5-2 Debian:13.1/stable [amd64])
Inst cryptsetup (2:2.7.5-2 Debian:13.1/stable [amd64])
Inst calamares-settings-debian (13.0.13-1 Debian:13.1/stable [all])
Inst cracklib-runtime (2.9.6-5.2+b1 Debian:13.1/stable [amd64])
Inst menu (2.1.51 Debian:13.1/stable [amd64])
Conf s4-snapshot-extq (1.1-a1 trixie-s4-snapshot repository:13.0/trixie-s4-snapshot-st [amd64])
Conf libpwquality-common (1.4.5-5 Debian:13.1/stable [all])
Conf libcrack2 (2.9.6-5.2+b1 Debian:13.1/stable [amd64])
Conf libpwquality1 (1.4.5-5 Debian:13.1/stable [amd64])
Conf libyaml-cpp0.8 (0.8.0+dfsg-7 Debian:13.1/stable [amd64])
Conf calamares (3.3.14-1 Debian:13.1/stable [amd64])
Conf cryptsetup-bin (2:2.7.5-2 Debian:13.1/stable [amd64])
Conf cryptsetup (2:2.7.5-2 Debian:13.1/stable [amd64])
Conf calamares-settings-debian (13.0.13-1 Debian:13.1/stable [all])
Conf cracklib-runtime (2.9.6-5.2+b1 Debian:13.1/stable [amd64])
Conf menu (2.1.51 Debian:13.1/stable [amd64])
Testing installation ... Done
Downloading packages ...
Suggested packages:
cdck
localize-repo
xorriso
Need to get 26.2 MB of archives.
After this operation, 45.4 MB of additional disk space will be used.
0% [Working]
Get:1 http://deb.debian.org/debian trixie/main amd64 whois amd64 5.6.3 [72.4 kB]
0% [1 whois 33.6 kB/72.4 kB 46%]
1% [Working]
Get:2 http://deb.debian.org/debian trixie/main amd64 squashfs-tools amd64 1:4.6.1-1 [194 kB]
1% [2 squashfs-tools 15.4 kB/194 kB 8%]
3% [Waiting for headers]
Get:3 http://deb.debian.org/debian trixie/main amd64 syslinux-utils amd64 3:6.04~git20190206.bf6db5b4+dfsg1-3.1 [78.2 kB]
3% [3 syslinux-utils 12.3 kB/78.2 kB 16%]
4% [Waiting for headers]
Get:4 http://deb.debian.org/debian trixie/main amd64 libburn4t64 amd64 1.5.6-1.1+b1 [164 kB]
4% [4 libburn4t64 3,294 B/164 kB 2%]
5% [Working]
Get:5 http://deb.debian.org/debian trixie/main amd64 libjte2 amd64 1.22-4+b2 [29.6 kB]
5% [5 libjte2 11.0 kB/29.6 kB 37%]
6% [Waiting for headers]
Get:6 http://deb.debian.org/debian trixie/main amd64 libisofs6t64 amd64 1.5.6.pl01-1.1+b1 [219 kB]
6% [6 libisofs6t64 46.0 kB/219 kB 21%]
8% [Waiting for headers]
Get:7 http://deb.debian.org/debian trixie/main amd64 libisoburn1t64 amd64 1.5.6-1.2+b1 [410 kB]
8% [7 libisoburn1t64 23.1 kB/410 kB 6%]
10% [Waiting for headers]
Get:8 http://deb.debian.org/debian trixie/main amd64 xorriso amd64 1.5.6-1.2+b1 [323 kB]
10% [8 xorriso 16.4 kB/323 kB 5%]
12% [Waiting for headers]
Get:9 http://deb.debian.org/debian trixie/main amd64 libpwquality-common all 1.4.5-5 [51.9 kB]
12% [9 libpwquality-common 8,716 B/51.9 kB 17%]
13% [Working]
Get:10 http://deb.debian.org/debian trixie/main amd64 libcrack2 amd64 2.9.6-5.2+b1 [44.4 kB]
13% [10 libcrack2 21.5 kB/44.4 kB 48%]
14% [Waiting for headers]
Get:11 http://deb.debian.org/debian trixie/main amd64 libpwquality1 amd64 1.4.5-5 [13.2 kB]
14% [11 libpwquality1 13.2 kB/13.2 kB 100%]
Get:12 http://deb.debian.org/debian trixie/main amd64 libyaml-cpp0.8 amd64 0.8.0+dfsg-7 [133 kB]
15% [12 libyaml-cpp0.8 27.8 kB/133 kB 21%]
16% [Waiting for headers]
Get:13 http://deb.debian.org/debian trixie/main amd64 calamares amd64 3.3.14-1 [4,230 kB]
16% [13 calamares 0 B/4,230 kB 0%]
29% [Waiting for headers]
Get:14 http://deb.debian.org/debian trixie/main amd64 cryptsetup-bin amd64 2:2.7.5-2 [504 kB]
30% [14 cryptsetup-bin 28.7 kB/504 kB 6%]
32% [Waiting for headers]
Get:15 http://deb.debian.org/debian trixie/main amd64 cryptsetup amd64 2:2.7.5-2 [230 kB]
32% [15 cryptsetup 8,694 B/230 kB 4%]
33% [Waiting for headers]
Get:16 http://deb.debian.org/debian trixie/main amd64 calamares-settings-debian all 13.0.13-1 [129 kB]
33% [16 calamares-settings-debian 0 B/129 kB 0%]
35% [Working]
Get:17 http://deb.debian.org/debian trixie/main amd64 cracklib-runtime amd64 2.9.6-5.2+b1 [143 kB]
35% [17 cracklib-runtime 0 B/143 kB 0%]
36% [Waiting for headers]
Get:18 http://deb.debian.org/debian trixie/main amd64 menu amd64 2.1.51 [355 kB]
36% [18 menu 27.7 kB/355 kB 8%]
38% [Working]
38% [Connecting to q4os.sourceforge.io]
38% [Connecting to q4os.sourceforge.io] 1,203 kB/s 15s
Get:19 https://q4os.sourceforge.io/qexarepo/s4-snapshot trixie-s4-snapshot-cn/main amd64 s4-iso-template amd64 25.9.01mx25.1301 [18.3 MB]
68% [19 s4-iso-template 9,781 kB/18.3 MB 53%] 510 kB/s 17s
94% [19 s4-iso-template 18.2 MB/18.3 MB 100%] 513 kB/s 1s
95% [Working] 513 kB/s 1s
Get:20 https://q4os.sourceforge.io/qexarepo/s4-snapshot trixie-s4-snapshot-cn/main amd64 covix-libs all 0.8.14+10mx25.1301 [93.6 kB]
95% [20 covix-libs 63.0 kB/93.6 kB 67%] 513 kB/s 1s
96% [Waiting for headers] 513 kB/s 1s
Get:21 https://q4os.sourceforge.io/qexarepo/s4-snapshot trixie-s4-snapshot-cn/main amd64 s4-remaster all 25.06.02mx25.1301 [184 kB]
96% [21 s4-remaster 32.4 kB/184 kB 18%] 513 kB/s 0s
97% [Waiting for headers] 513 kB/s 0s
Get:22 https://q4os.sourceforge.io/qexarepo/s4-snapshot trixie-s4-snapshot-cn/main amd64 s4-snapshot amd64 25.09.2.1301 [345 kB]
97% [22 s4-snapshot 46.9 kB/345 kB 14%] 513 kB/s 0s
99% [Waiting for headers] 513 kB/s 0s
Get:23 https://q4os.sourceforge.io/qexarepo/s4-snapshot trixie-s4-snapshot-cn/main amd64 s4-snapshot-extq amd64 1.1-a1 [2,580 B]
99% [23 s4-snapshot-extq 2,580 B/2,580 B 100%] 513 kB/s 0s
100% [Working] 513 kB/s 0s
Fetched 26.2 MB in 44s (596 kB/s)
Download complete and in download only mode
Downloading packages ... Done
Copying system packages ...
Suggested packages:
cdck
localize-repo
xorriso
Need to get 0 B/26.2 MB of archives.
Preconfiguring packages ...
Selecting previously unselected package s4-iso-template.
(Reading database ... 100%
(Reading database ... 212472 files and directories currently installed.)
Preparing to unpack .../00-s4-iso-template_25.9.01mx25.1301_amd64.deb ...
Unpacking s4-iso-template (25.9.01mx25.1301) ...
Selecting previously unselected package covix-libs.
Preparing to unpack .../01-covix-libs_0.8.14+10mx25.1301_all.deb ...
Unpacking covix-libs (0.8.14+10mx25.1301) ...
Selecting previously unselected package whois.
Preparing to unpack .../02-whois_5.6.3_amd64.deb ...
Unpacking whois (5.6.3) ...
Selecting previously unselected package s4-remaster.
Preparing to unpack .../03-s4-remaster_25.06.02mx25.1301_all.deb ...
Unpacking s4-remaster (25.06.02mx25.1301) ...
Selecting previously unselected package squashfs-tools.
Preparing to unpack .../04-squashfs-tools_1%3a4.6.1-1_amd64.deb ...
Unpacking squashfs-tools (1:4.6.1-1) ...
Selecting previously unselected package syslinux-utils.
Preparing to unpack .../05-syslinux-utils_3%3a6.04~git20190206.bf6db5b4+dfsg1-3.1_amd64.deb ...
Unpacking syslinux-utils (3:6.04~git20190206.bf6db5b4+dfsg1-3.1) ...
Selecting previously unselected package libburn4t64:amd64.
Preparing to unpack .../06-libburn4t64_1.5.6-1.1+b1_amd64.deb ...
Unpacking libburn4t64:amd64 (1.5.6-1.1+b1) ...
Selecting previously unselected package libjte2:amd64.
Preparing to unpack .../07-libjte2_1.22-4+b2_amd64.deb ...
Unpacking libjte2:amd64 (1.22-4+b2) ...
Selecting previously unselected package libisofs6t64:amd64.
Preparing to unpack .../08-libisofs6t64_1.5.6.pl01-1.1+b1_amd64.deb ...
Unpacking libisofs6t64:amd64 (1.5.6.pl01-1.1+b1) ...
Selecting previously unselected package libisoburn1t64:amd64.
Preparing to unpack .../09-libisoburn1t64_1.5.6-1.2+b1_amd64.deb ...
Unpacking libisoburn1t64:amd64 (1.5.6-1.2+b1) ...
Selecting previously unselected package xorriso.
Preparing to unpack .../10-xorriso_1.5.6-1.2+b1_amd64.deb ...
Unpacking xorriso (1.5.6-1.2+b1) ...
Selecting previously unselected package s4-snapshot.
Preparing to unpack .../11-s4-snapshot_25.09.2.1301_amd64.deb ...
Adding initrd_release ...
Diverting Calamares launcher ...
Unpacking s4-snapshot (25.09.2.1301) ...
Setting up s4-iso-template (25.9.01mx25.1301) ...
Setting up covix-libs (0.8.14+10mx25.1301) ...
Setting up whois (5.6.3) ...
Setting up s4-remaster (25.06.02mx25.1301) ...
Created symlink '/etc/systemd/system/multi-user.target.wants/live-broadcomstartup.service' → '/usr/lib/systemd/system/live-broadcomstartup.service'.
Created symlink '/etc/systemd/system/multi-user.target.wants/live-clock12or24.service' → '/usr/lib/systemd/system/live-clock12or24.service'.
Created symlink '/etc/systemd/system/multi-user.target.wants/live-swap.service' → '/usr/lib/systemd/system/live-swap.service'.
Created symlink '/etc/systemd/system/multi-user.target.wants/live-static-shutdown.service' → '/usr/lib/systemd/system/live-static-shutdown.service'.
Created symlink '/etc/systemd/system/multi-user.target.wants/live-usb-save.service' → '/usr/lib/systemd/system/live-usb-save.service'.
Created symlink '/etc/systemd/system/multi-user.target.wants/persist-autosave.service' → '/usr/lib/systemd/system/persist-autosave.service'.
Created symlink '/etc/systemd/system/sysinit.target.wants/hwclock-mx.service' → '/usr/lib/systemd/system/hwclock-mx.service'.
Setting up squashfs-tools (1:4.6.1-1) ...
Setting up syslinux-utils (3:6.04~git20190206.bf6db5b4+dfsg1-3.1) ...
Setting up libburn4t64:amd64 (1.5.6-1.1+b1) ...
Setting up libjte2:amd64 (1.22-4+b2) ...
Setting up libisofs6t64:amd64 (1.5.6.pl01-1.1+b1) ...
Setting up libisoburn1t64:amd64 (1.5.6-1.2+b1) ...
Setting up xorriso (1.5.6-1.2+b1) ...
Setting up s4-snapshot (25.09.2.1301) ...
Selecting previously unselected package s4-snapshot-extq.
(Reading database ... 213067 files and directories currently installed.)
Preparing to unpack .../00-s4-snapshot-extq_1.1-a1_amd64.deb ...
Unpacking s4-snapshot-extq (1.1-a1) ...
Selecting previously unselected package libpwquality-common.
Preparing to unpack .../01-libpwquality-common_1.4.5-5_all.deb ...
Unpacking libpwquality-common (1.4.5-5) ...
Selecting previously unselected package libcrack2:amd64.
Preparing to unpack .../02-libcrack2_2.9.6-5.2+b1_amd64.deb ...
Unpacking libcrack2:amd64 (2.9.6-5.2+b1) ...
Selecting previously unselected package libpwquality1:amd64.
Preparing to unpack .../03-libpwquality1_1.4.5-5_amd64.deb ...
Unpacking libpwquality1:amd64 (1.4.5-5) ...
Selecting previously unselected package libyaml-cpp0.8:amd64.
Preparing to unpack .../04-libyaml-cpp0.8_0.8.0+dfsg-7_amd64.deb ...
Unpacking libyaml-cpp0.8:amd64 (0.8.0+dfsg-7) ...
Selecting previously unselected package calamares.
Preparing to unpack .../05-calamares_3.3.14-1_amd64.deb ...
Unpacking calamares (3.3.14-1) ...
Selecting previously unselected package cryptsetup-bin.
Preparing to unpack .../06-cryptsetup-bin_2%3a2.7.5-2_amd64.deb ...
Unpacking cryptsetup-bin (2:2.7.5-2) ...
Selecting previously unselected package cryptsetup.
Preparing to unpack .../07-cryptsetup_2%3a2.7.5-2_amd64.deb ...
Unpacking cryptsetup (2:2.7.5-2) ...
Selecting previously unselected package calamares-settings-debian.
Preparing to unpack .../08-calamares-settings-debian_13.0.13-1_all.deb ...
Unpacking calamares-settings-debian (13.0.13-1) ...
Selecting previously unselected package cracklib-runtime.
Preparing to unpack .../09-cracklib-runtime_2.9.6-5.2+b1_amd64.deb ...
Unpacking cracklib-runtime (2.9.6-5.2+b1) ...
Selecting previously unselected package menu.
Preparing to unpack .../10-menu_2.1.51_amd64.deb ...
Unpacking menu (2.1.51) ...
Setting up libpwquality-common (1.4.5-5) ...
Setting up cryptsetup-bin (2:2.7.5-2) ...
Setting up cryptsetup (2:2.7.5-2) ...
Setting up libyaml-cpp0.8:amd64 (0.8.0+dfsg-7) ...
Setting up libcrack2:amd64 (2.9.6-5.2+b1) ...
Setting up s4-snapshot-extq (1.1-a1) ...
Distro [trixie], adding repositories, configuring ...
Setting up menu (2.1.51) ...
Setting up cracklib-runtime (2.9.6-5.2+b1) ...
Setting up libpwquality1:amd64 (1.4.5-5) ...
Setting up calamares (3.3.14-1) ...
Setting up calamares-settings-debian (13.0.13-1) ...
Processing triggers for man-db (2.13.1-1) ...
Processing triggers for libglib2.0-0t64:amd64 (2.84.4-3~deb13u1) ...
Processing triggers for mailcap (3.74) ...
Processing triggers for desktop-file-utils (0.28-1) ...
Processing triggers for hicolor-icon-theme (0.18-2) ...
Processing triggers for libc-bin (2.41-12) ...
Processing triggers for menu (2.1.51) ...
Copying system packages ... Done
Configuring Apt ...
Configuring Apt ... Done
Checking installation ...
Checking installation ... OK
Postinstall operations ...
Postinstall operations ... Done
Registering application ... OK
Finishing installation ...
Installation successfully completed :-)
repo list:
germ@q4os:~$ qrepolist
deb http://q4os.org/q4repo/ q4os-6-0-cn main
deb http://deb.debian.org/debian/ trixie main contrib non-free non-free-firmware
deb http://security.debian.org/ trixie-security main contrib non-free non-free-firmware
deb http://deb.debian.org/debian/ trixie-updates main contrib non-free non-free-firmware
deb http://q4os.org/qexarepo/chrome/ trixie-chrome-cn main
deb https://dl.google.com/linux/chrome/deb/ stable main
deb http://mirrors.rit.edu/mxlinux/mx-packages/mx/repo/ trixie main non-free ahs
deb https://q4os.sourceforge.io/qexarepo/mxtools/ trixie-mxtools-cn main
After checking the install log, it says installed successfully.  I checked and they are installed, and work.
So even though it said it failed, they actually did install.
Strange...
#5 2025-11-08 16:46
What if you run the setup_q4os-mxtools-plasma_5.3-a1.qsi setup once again ?
For what command ?
Germ wrote:
Strange ..
Yes, run command and post the output:
ls -l $HOME/.appsetup2/log/
#6 2025-11-08 17:25
Germ
Running again with qsi installer shows:
MX Tools software is already installed, so cancelling installation ...
Tried to run from terminal with command
"setup_q4os-mxtools-plasma_5.3-a1.qsi" and again with
"./setup_q4os-mxtools-plasma_5.3-a1.qsi"
Both returned permission denied as user and root
germ@q4os:~$ ls -l $HOME/.appsetup2/log/
total 200
-rw-rw-r-- 1 germ germ  13900 Nov  8 09:08 setup-com.vivaldi.Vivaldi_20251108090727.log
-rw-rw-r-- 1 germ germ   3209 Sep 12 12:10 setup-falkon_20250912121007.log
-rw-rw-r-- 1 germ germ   7245 Sep 12 16:42 setup-q4os-chrome_20250912164151.log
-rw-rw-r-- 1 germ germ   8888 Sep 12 16:44 setup-q4os-gparted_20250912164335.log
-rw-rw-r-- 1 germ germ   8971 Sep 12 12:09 setup-q4os-ipcodecs_20250912120902.log
-rw-rw-r-- 1 germ germ 130659 Nov  7 15:25 setup-q4os-mxtools-plasma_20251107150922.log
-rw-rw-r-- 1 germ germ      0 Nov  8 07:42 setup-q4os-mxtools-plasma_20251108074247.log
-rw-rw-r-- 1 germ germ  19325 Sep 18 11:41 setup-s4-snapshot-extq_20250918113948.log
#7 2025-11-08 20:37
You can't execute the installer directly. Instead do:
$ appsetup2.exu setup_q4os-mxtools-plasma_5.3-a1.qsi
It's really curious. We would like to solve it. Please run in terminal:
$ reportq4
and send the debug file generated via email support@q4os.org , or attach it here for us to analyze.
#8 2025-11-08 22:30
Germ
reportq4 emailed.
#9 2025-11-08 23:07
We confirm reception of reportq4. As we have took a look something is not correct here. Some essential log files are truncated to the 1 byte size. So before we can conclude possible issues, please run the command and post back:
$ sudo ls -l /var/log/live_inst/
#10 2025-11-09 16:06
Germ
germ@q4os:~$ sudo ls -l /var/log/live_inst/
[sudo] password for germ:
total 20
-rw-r--r-- 1 root root 1 Nov  8 07:56 q4hook1.log
-rw-r--r-- 1 root root 1 Nov  8 07:56 q4hook2.log
-rw-r--r-- 1 root root 1 Nov  8 07:56 q4hook3.log
-rw-r--r-- 1 root root 1 Nov  8 07:56 q4hook5.log
-rw-r--r-- 1 root root 1 Nov  8 07:56 q4hook_bootloaderconfig.log
#11 2025-11-09 16:28
It seems that something went wrong during or after the installation. The log files are 1 byte in size. Unfortunately, we have too few information to determine what is wrong, and the log files are also missing. Could it be a hard drive problem ? For now, we can only recommend that you check if the hardware is fine and perform a fresh installation.
#12 2025-11-09 16:47
Germ
I don't think it's the hard drive.  It's less than a year old.  The system is fast and responsive with no other errors.  I'll do some checking.
I have used the QSI Installer to install other things without error messages and the MX Tools did install OK.  I just thought they did not by the error message.
I'll keep it "as is" and report back if something becomes apparent.
Thank you for your efforts.  smile
#13 2025-11-09 16:54
Okay. There are at least two strange things going on in your system (mx-tools installer fail and truncated log files), so keep an eye out for that. If you need any more help, feel free to ask smile
#14 2025-11-10 17:35
Germ
I've noticed another little glitch.  There is a "Install Debian" link on the Desktop.  I delete it and next boot it re-appears.  Not a big deal, but annoying.  It has happened three boots in a row.
I'm thinking about re-doing the Q4OS install.
#15 2025-11-10 18:36
It appears MX tools hasn't been installed properly. You can make a check:
$ ls -l /usr/bin/add-calamares-desktop-icon*
$ dpkg -S /usr/bin/add-calamares-desktop-icon
and post back the result.
#16 2025-11-10 22:56
Germ
germ@q4os:~$ ls -l /usr/bin/add-calamares-desktop-icon*
-rwxr-xr-x 1 root root 1870 Jul 13 16:49 /usr/bin/add-calamares-desktop-icon
germ@q4os:~$ dpkg -S /usr/bin/add-calamares-desktop-icon
calamares-settings-debian: /usr/bin/add-calamares-desktop-icon
#17 2025-11-10 23:34
We can see Mx-tools are not installed correctly because "add-calamares-desktop-icon" binary isn't diverted as it should be. We would recommend you to reinstall mx-tools.
- First of all do removals:
$ sudo apt --purge autoremove s4-*
$ sudo apt --purge autoremove mx-*
$ sudo apt --purge autoremove q4os-mxtools*
$ sudo apt --purge autoremove q4os-s4-snapshot
- Download the most recent Mx-tools Plasma installer from https://sourceforge.net/projects/q4os/f … ntal_apps/ and install it.
- Post output of the commands for us to check:
This procedure may fix all the glitches you encountered.
#18 2025-11-11 02:32
Germ
-rwxr-xr-x 1 root root  219 Sep 25 06:45 /usr/bin/add-calamares-desktop-icon
-rwxr-xr-x 1 root root 1870 Jul 13 16:49 /usr/bin/add-calamares-desktop-icon.real1
diversion by mx-snapshot from: /usr/bin/add-calamares-desktop-icon
diversion by mx-snapshot to: /usr/bin/add-calamares-desktop-icon.real1
calamares-settings-debian, mx-snapshot: /usr/bin/add-calamares-desktop-icon
Yep, that fixed it.  Thank you!
#19 2025-11-11 11:31
Yes, seems to be fixed  smile hopefully in complete.
