#1 2025-11-03 23:07
rickfromtheinternet
installed a program but cannot uninstall easily
i installed a program and the trial period ran out it was a trustworthy .deb file how would i go about removing this as it was a program not from the repository so therefor uninstalling in the usual way by right clicking in the menu failed.
#2 2025-11-03 23:14
Re: installed a program but cannot uninstall easily
You need to run in terminal:
$ sudo apt autoremove <the_package_name>
#3 2025-11-04 04:31
rickfromtheinternet
thank you although  i feel a bit silly because it was that simple
#4 2025-11-04 10:04
You are welcome. Any package should have this format:
<package_name>_<package_version>_<cpu_arch>.deb
