#1 2025-11-03 09:49
THN
funny, KDE says I have no webcam
Hi,
another little hick-up with KDE plasma...
My MS webcam is working perfectly with cheese and guvcview, but the "camera usage indicator" in the system tray (bottom right) always shows a strikethrough indicator (no camera in use).
Upstream issue?
Best regards
T.
#2 2025-11-03 14:58
Re: funny, KDE says I have no webcam
I get the same with the built in camera on my old Lenovo Thinkpad E530. Camera works but nothing in the tray. Never even noticed it till you mentioned it!!!! smile
#3 2025-11-03 15:24
Are you using Q4OS, Debian, or another distro ? What version ?
#4 2025-11-03 15:56
We can reproduce this on a plain Debian 13 Trixie Plasma, the default installation. Running Cheese application ok, but no camera indicator in the system tray. So we would conclude upstream issue.
#5 2025-11-03 16:03
Do you have any camera present in the system settings > disks and camers > digital camera module ?
Installing "kamera" package may also do the trick. Post back the result please.
#6 2025-11-04 08:49
Kamera package makes no difference.
System:
  Kernel: 6.12.48+deb13-amd64 arch: x86_64 bits: 64 compiler: gcc v: 14.2.0
    clocksource: tsc
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_x11 vt: 2 dm: SDDM
    Distro: Q4OS 6.2.1-deb13u1 base: Debian GNU/Linux 13 (trixie)
Machine:
  Type: Laptop System: LENOVO product: 627227G v: ThinkPad Edge E530
    serial: <superuser required> Chassis: type: 10 serial: <superuser required>
  Mobo: LENOVO model: 627227G v: Win8 Pro DPK TPG
    serial: <superuser required> part-nu: LENOVO_MT_6272
    uuid: <superuser required> UEFI: LENOVO v: H0ET94WW (2.54 )
    date: 08/02/2013
Battery:
  ID-1: BAT0 charge: 48.8 Wh (100.0%) condition: 48.8/48.8 Wh (100.0%)
    volts: 12.1 min: 11.1 model: SANYO 11 45N1043 type: Li-ion serial: <filter>
    status: full
Memory:
  System RAM: total: 16 GiB available: 15.47 GiB used: 1.74 GiB (11.2%)
  Message: For most reliable report, use superuser + dmidecode.
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
    max-module-size: 8 GiB note: est.
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Hynix/Hyundai part-no: HMT41GS6BFR8A-PB serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
CPU:
  Info: dual core model: Intel Core i3-3110M bits: 64 type: MT MCP
    smt: enabled arch: Ivy Bridge rev: 9 cache: L1: 128 KiB L2: 512 KiB
    L3: 3 MiB
  Speed (MHz): avg: 1500 min/max: 1200/2400 cores: 1: 1500 2: 1500 3: 1500
    4: 1500 bogomips: 19156
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-7 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: Ricoh Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 bus-ID: 1-1.6:3 chip-ID: 05ca:1823 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: modesetting unloaded: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: LVDS-1 model: LG Display 0x033b res: mode: 1366x768 hz: 60
    scale: 100% (1) dpi: 101 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 25.0.7-2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
    device-ID: 8086:0166
  API: Vulkan v: 1.4.309 layers: 4 surfaces: xcb,xlib device: 0
    type: integrated-gpu driver: mesa intel device-ID: 8086:0166 device: 1
    type: cpu driver: mesa llvmpipe device-ID: 10005:0000
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
    de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
    xdpyinfo, xprop, xrandr
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  API: ALSA v: k6.12.48+deb13-amd64 status: kernel-api
  Server-1: aRts v: 1.5.10 status: off with: artswrapper status: off
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active
  Server-3: PulseAudio v: 17.0 status: off (using pipewire-pulse)
Network:
  Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:0888 class-ID: 0280
  IF: wlp3s0 state: up mac: <filter>
  Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp12s0 state: down mac: <filter>
Drives:
  Local Storage: total: 223.57 GiB used: 51.64 GiB (23.1%)
  ID-1: /dev/sda vendor: SanDisk model: SSD PLUS 240GB size: 223.57 GiB
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
Partition:
  ID-1: / size: 20.31 GiB used: 8.15 GiB (40.2%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 998 MiB used: 7 MiB (0.7%) fs: vfat dev: /dev/sda1
  ID-3: /home size: 197.57 GiB used: 43.48 GiB (22.0%) fs: ext4
    dev: /dev/sda3
Swap:
  Alert: No swap data was found.
Sensors:
  System Temperatures: cpu: 50.0 C mobo: N/A
  Fan Speeds (rpm): N/A
Repos:
  Packages: pm: dpkg pkgs: 2221
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/10_q4os.sources
    1: deb http://q4os.org/q4repo/ q4os-6-0-cn main
  Active apt repos in: /etc/apt/sources.list.d/20_debian.sources
    1: deb http://deb.debian.org/debian/ trixie main contrib non-free non-free-firmware
    2: deb http://security.debian.org/ trixie-security main contrib non-free non-free-firmware
    3: deb http://deb.debian.org/debian/ trixie-updates main contrib non-free non-free-firmware
  Active apt repos in: /etc/apt/sources.list.d/winehq-trixie.sources
    1: deb [arch=amd64 i386] https://dl.winehq.org/wine-builds/debian trixie main
Info:
  Processes: 190 Power: uptime: 23m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: systemd v: 257 default: graphical
  Compilers: N/A Shell: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
Tested with vokoscreen-ng
Camera works fine, but system seems unaware of it. Nothing shows in System Settings>Connected Devices
#7 2025-11-04 09:59
Thanks @bin
@THN
If you post the information, it will help us track the issue.
- Are you running Q4OS, Debian, or another distro ? What version ?
- Do you have any camera present in the system settings > disks and camers > digital camera module ?
- Installing "kamera" package may also do the trick. Post back the result please.
