#26 2025-10-19 21:46
Re: Trinity Bugs and Issues
Try to clear cache:
$ rm -r $HOME/.cache
and post back the result
#27 2025-10-19 22:10
huh i cant reproduce this issue in q4os 6.. maybe i should mark it as fixed
Coding & Robotics Enthusiast | Q4OS 5 TDE @ n2600 · 2GB · 320GB HDD
#28 2025-10-20 08:42
BLOCK_5 - Sometimes when trying to open menu but it doesn't open on the first try so you click the button repeatedly and then when it shows up and you close it OR it just opens and closes repeatedly and closes, keyboard stops working, I can no longer register keypresses. To fix it you need to open and close menu one more time, after that i can input keyboard stokes as normal
Can you reproduce it in Q4OS-6 ?
#29 2025-10-20 10:29
I actually don't use the default binding anymore, I'm using the new (unreleased) Xakar to handle super_l for starting the menu, so I can't reproduce it..
#30 2025-10-21 10:06
TDEIO ISSUES BLOCK_1+BLOCK_2
They seem to be upstream Trinity issues.
#31 2025-10-21 12:55
Block 2 is more of a samba lack of feature, which was added in version 4.23. Here's the workaround for it https://www.q4os.org/forum/viewtopic.php?id=5735
#32 2025-10-30 12:24
THEMING ISSUES BLOCK_1+_2+_3
We can confirm block_1+_2+_3 issues.
#33 2025-11-03 14:20
THEMING ISSUES BLOCK_4+_5+_6
We can confirm block_4+_5+_6 issues.
#34 2025-11-03 14:21
THEMING ISSUES BLOCK_7
We don't understand what is the issue. Please specify in more detail.
#35 2025-11-03 16:19
Nevermind, it seems good now.. I'll update op soon
#36 2025-11-04 12:00
THEMING ISSUES BLOCK_8
We can confirm block_8 issue.
#37 2025-11-05 14:23
THEMING ISSUES BLOCK_9
Fixed.
THEMING ISSUES BLOCK_10
We don't consider this a bug, more of a deliberate design. How would you imagine styling this icon ?
THEMING ISSUES BLOCK_11
We can confirm block_11 issue.
#38 2025-11-06 01:58
Huh.. maybe a dark icon when using dark theme? Or maybe typing it as text instead of fixed icon?
#39 2025-11-06 09:31
KATE ISSUES BLOCK_1
Could you describe step by step how to reproduce the problem? We haven't been able to reproduce that yet.
#40 2025-11-06 09:33
Q4OS logo has standard colors and looks fine in the dark theme by our opinion. However, if you would design some draft we can consider to replace it in the dark themes.
#41 2025-11-06 14:15
The icon looks good, I was talking about the text "Q4OS"
#42 2025-11-06 14:18
KATE ISSUES BLOCK_1
Try pasting something in kate's embedded konsole using keyboard shortcuts, it'd be pasted onto the editor object instead of konsole.
#43 2025-11-07 13:08
KATE ISSUES BLOCK_1+_2
We can confirm block_1+_2 issues. They seems to be Trinity upstream both.
#44 2026-01-21 06:06
sara
This is not so much a Q4OS bug as it is Trinity/Kicker upstream debt.
The kicker's colored line and shadow are hardcoded highlight logic; themes cannot completely change them. That would only be resolved with a hide option or patch.
The massive RecentAppsStat/FirstSeenApps in kickerrc is probably the cause of the menu latency. On low-RAM systems, kicker chokes. The hangs are typically immediately resolved by deleting the items or recreating the file.
Since they are different stacks, a mismatch between gvfs and tdeio trash/smb is to be expected. For the same reason, SMB functions in Thunar but not in Conqueror.
Kate focus/shortcut oddity is also recognized as upstream behavior rather than distro-specific.
