#1 2025-10-25 22:36
rickfromtheinternet
i have issues getting ksnip to work
when i try to use ksnip i get an error that says
" no image provided but one was expected "
i have no idea how to trouble shoot this program would anyone happen to know a fix or an alternative program that i could use instead
thank you
#2 2025-10-26 08:44
Re: i have issues getting ksnip to work
You don't give information on your system, so maybe the following is irrelevant :
- see https://github.com/ksnip/ksnip/issues/1026
- see also https://github.com/ksnip/ksnip?tab=read … shot-types
Definitely not a Q4OS issue.
I'm using Spectacle without issue on Q4OS 4 / Plasma.
#3 2025-10-26 13:18
Are you using Wayland? If so switch to X11 on the login screen and all will be OK as per the links provided by @hchiper
