#1 2025-10-17 07:39
[Closed] TDE: Configure Hotkey Settings Broken
Under settings://Accessibility when trying to open "Input Actions" it pops up an "Open With" window.. it says "The file or folder does not exist" when trying to run any command/trying to preview in embedded editor
I can still access the settings using terminal via, tdecmshell khotkeys
#2 2025-10-17 12:08
Re: [Closed] TDE: Configure Hotkey Settings Broken
Yes, we can confirm this issue. Although it's an upstream one, we will fix it. You can workaround it in the meantime this way:
$ sudo mv /opt/trinity/share/applications/tde/khotkeys.desktop /opt/trinity/share/applications/tde/khotkeys2.desktop
#3 2025-12-04 17:51
This bug has been fixed in Q4OS, you only need to update from repositories and reboot.
