#1 2025-10-14 14:53
Spotify refuses to run.
I have installed Flatpak from Q4OS Software Centre, than installed Spotify from Flathub. But, installed Spotify refuses to launch.
Please watch video: https://drive.google.com/file/d/14oPDdq … sp=sharing
My system information:
denis@g41m-andromeda:~$ inxi -Fz
System:
  Kernel: 6.12.48+deb13-amd64 arch: x86_64 bits: 64
  Desktop: TDE (Trinity) v: R14.1.5 Distro: Q4OS 6.1.3-deb13u1
Machine:
  Type: Desktop Mobo: Gigabyte model: G41M-Combo v: x.x
    serial: <superuser required> BIOS: Award v: FB date: 10/25/2012
CPU:
  Info: quad core model: Intel Core2 Quad Q9550 bits: 64 type: MCP cache:
    L2: 12 MiB
  Speed (MHz): avg: 2000 min/max: 2000/2834 cores: 1: 2000 2: 2000 3: 2000
    4: 2000
Graphics:
  Device-1: NVIDIA GK208B [GeForce GT 710] driver: nouveau v: kernel
  Display: x11 server: X.Org v: 21.1.16 driver: X: loaded: nouveau
    unloaded: fbdev,modesetting,vesa dri: swrast gpu: nouveau
    resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: nouveau,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.0.7-2
    renderer: llvmpipe (LLVM 19.1.7 128 bits)
  API: Vulkan v: 1.4.309 drivers: llvmpipe surfaces: xcb,xlib
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo x11: xdriinfo,
    xdpyinfo, xprop, xrandr
Audio:
  Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
  Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel
  API: ALSA v: k6.12.48+deb13-amd64 status: kernel-api
  Server-1: aRts v: 1.5.10 status: active
  Server-2: PipeWire v: 1.4.2 status: active
Network:
  Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet driver: atl1c
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 232.89 GiB used: 15.86 GiB (6.8%)
  ID-1: /dev/sda vendor: Crucial model: CT250MX500SSD1 size: 232.89 GiB
Partition:
  ID-1: / size: 219.88 GiB used: 15.86 GiB (7.2%) fs: ext4 dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 8.42 GiB used: 0 KiB (0.0%)
    dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: nouveau temp: 34.0 C
  Fan Speeds (rpm): cpu: 796 fan-2: 1273
Info:
  Memory: total: 4 GiB available: 3.83 GiB used: 1.24 GiB (32.3%)
  Processes: 214 Uptime: 13m Shell: Bash inxi: 3.3.38
Please help.
#2 2025-10-14 15:21
Re: Spotify refuses to run.
Update.
I have removed Spotify, and, after that, installed it again using Q4OS Software Centre.
Installation was successful, but Spotify again refuses to run with the same error Failed to load module "xapp-gtk3-module" (attachment).
Installation log:
Вычисляется прогресс…
Проверяется соединение с Интернетом…
Проверяется соединение с Интернетом… ОК
Устанавливается пакет…
F: Opening system flatpak installation at path /var/lib/flatpak
Поиск совпадений…
F: Fetching summary index file for remote ‘flathub’
F: Loading https://dl.flathub.org/repo/summary.idx using curl
F: Received 10001 bytes
F: Loading https://dl.flathub.org/repo/summaries/ff90667737cf4d364a5de96566e73f6c6825e417bf41047470ea678343d36648.idx.sig using curl
F: Received 592 bytes
F: Fetching indexed summary file ae2e9c8af99179886fc2de23bef170ac2744c8d4a46c5098fb6803d9e0062fb7.gz for remote ‘flathub’
F: Loading https://dl.flathub.org/repo/summaries/ae2e9c8af99179886fc2de23bef170ac2744c8d4a46c5098fb6803d9e0062fb7.gz using curl
F: Received 1471322 bytes
F: No installations directory in /etc/flatpak/installations.d. Skipping
F: Loaded indexed summary file ae2e9c8af99179886fc2de23bef170ac2744c8d4a46c5098fb6803d9e0062fb7 from cache for remote ‘flathub’
F: Transaction: install flathub:app/com.spotify.Client/x86_64/stable[*]
F: Looking for remote metadata updates for flathub
F: marking op install:app/com.spotify.Client/x86_64/stable resolved to aeb385d0f92ef6470cd35a0c311dd311a98981b8721697c0adb354c5a3cd192e
F: Updating dependency org.freedesktop.Platform/x86_64/25.08 of com.spotify.Client/x86_64/stable
F: Transaction: update flathub:runtime/org.freedesktop.Platform/x86_64/25.08[$old]
F: marking op update:runtime/org.freedesktop.Platform/x86_64/25.08 resolved to bbdd6e18c2d84fc548c42216c49772f40069521a4267c45c4502e26cb0f823e2
F: Transaction: install/update flathub:runtime/org.freedesktop.Platform.GL.default/x86_64/25.08[*]
F: Transaction: install/update flathub:runtime/org.freedesktop.Platform.GL.default/x86_64/25.08-extra[*]
F: Transaction: install/update flathub:runtime/org.freedesktop.Platform.Locale/x86_64/25.08[/ru]
F: Transaction: install/update flathub:runtime/org.freedesktop.Platform.codecs-extra/x86_64/25.08-extra[*]
F: marking op install/update:runtime/org.freedesktop.Platform.codecs-extra/x86_64/25.08-extra resolved to 6ebd5a19d33f7bc523dc1e1c3c38d6cda093fe82d7448a5ed98b87a8124c5fe6
F: marking op install/update:runtime/org.freedesktop.Platform.Locale/x86_64/25.08 resolved to 4d971f1a3ab88820c9e792294e395452160d8875f62e7a59defc6d98edf9b9ce
F: marking op install/update:runtime/org.freedesktop.Platform.GL.default/x86_64/25.08-extra resolved to 526b98d1e89c088e01a21cf1741f4fc43b9780bdbe704f3b7f3ead02c932c462
F: marking op install/update:runtime/org.freedesktop.Platform.GL.default/x86_64/25.08 resolved to 726461e1c1bade0ea9cbd4335cdbfcb6e887dcba069aba3e8bfdd76ab049c016
F: Checking installation ‘system’ for EOL unused refs and autoprunes
F: Checking installation ‘system’ by checking for dependent refs in ‘user’
Разрешения com.spotify.Client:
ipc
network
pulseaudio
x11
dri
file access [1]
dbus access [2]
bus ownership [3]
tags [4]
[1] xdg-music:ro, xdg-pictures:ro
[2] org.gnome.SessionManager, org.gnome.SettingsDaemon.MediaKeys,
org.kde.StatusNotifierWatcher
[3] org.mpris.MediaPlayer2.spotify
[4] proprietary
com.spotify.Client
stable
flathub
< 208,6 МБ
Установка…
F: flatpak_dir_pull: Using commit aeb385d0f92ef6470cd35a0c311dd311a98981b8721697c0adb354c5a3cd192e for pull of ref app/com.spotify.Client/x86_64/stable from remote flathub
Установка… 0% 0 байт/s
Установка… 0%
Установка… █▌ 8%
Установка… █▌ 8% 535,7 КБ/s
Установка… █▌ 8% 1,7 МБ/s
Установка… █▊ 9% 2,2 МБ/s
Установка… ██ 10% 1,9 МБ/s
Установка… ██▏ 11% 2,9 МБ/s
Установка… ██▍ 12% 2,3 МБ/s 00:29
F: Loading https://api.snapcraft.io/api/v1/snaps/download/pOBIoZ2LrCB3rDohMxoYGnbN14EHOgD7_88.snap using curl
Установка… ██▍ 12% 1,7 МБ/s 00:44
Установка… ██▊ 14% 2,0 МБ/s 00:49
Установка… ███▊ 19% 2,9 МБ/s 00:38
Установка… ████▍ 22% 3,3 МБ/s 00:35
Установка… █████▏ 26% 3,7 МБ/s 00:31
Установка… █████▌ 28% 3,9 МБ/s 00:30
Установка… ██████▍ 32% 4,3 МБ/s 00:27
Установка… ███████▊ 39% 5,1 МБ/s 00:21
Установка… ████████▍ 42% 5,1 МБ/s 00:20
Установка… █████████▌ 48% 5,3 МБ/s 00:18
Установка… ██████████▏ 51% 5,5 МБ/s 00:17
Установка… ██████████▌ 53% 5,2 МБ/s 00:17
Установка… ██████████▊ 54% 5,0 МБ/s 00:17
Установка… ███████████ 55% 4,9 МБ/s 00:18
Установка… ███████████▏ 56% 4,8 МБ/s 00:18
Установка… ███████████▍ 57% 4,7 МБ/s 00:18
Установка… ███████████▊ 59% 4,7 МБ/s 00:17
Установка… ████████████▏ 61% 4,7 МБ/s 00:16
Установка… ████████████▊ 64% 4,7 МБ/s 00:15
Установка… █████████████▍ 67% 4,8 МБ/s 00:13
Установка… █████████████▊ 69% 4,8 МБ/s 00:13
Установка… ██████████████▏ 71% 4,8 МБ/s 00:12
Установка… ███████████████ 75% 4,9 МБ/s 00:10
Установка… ███████████████▍ 77% 4,9 МБ/s 00:09
Установка… ███████████████▊ 79% 4,9 МБ/s 00:08
Установка… ████████████████▍ 82% 4,9 МБ/s 00:07
Установка… █████████████████ 85% 5,0 МБ/s 00:06
Установка… █████████████████▊ 89% 5,1 МБ/s 00:04
Установка… ██████████████████▏ 91% 5,1 МБ/s 00:03
Установка… ██████████████████▊ 94% 5,1 МБ/s 00:02
Установка… ███████████████████▏ 96% 5,2 МБ/s 00:01
Установка… ███████████████████▌ 98% 5,1 МБ/s 00:00
Установка… ████████████████████ 100% 5,1 МБ/s 00:00
F: Received 198848512 bytes
F: No checksum specified, getting tip of app/com.spotify.Client/x86_64/stable from origin flathub
F: tip resolved to: aeb385d0f92ef6470cd35a0c311dd311a98981b8721697c0adb354c5a3cd192e
F: extracting extra data to /var/lib/flatpak/app/com.spotify.Client/x86_64/stable/.aeb385d0f92ef6470cd35a0c311dd311a98981b8721697c0adb354c5a3cd192e-wJ0ko0/files/extra
F: /var/lib/flatpak/runtime/org.freedesktop.Platform/x86_64/25.08/bbdd6e18c2d84fc548c42216c49772f40069521a4267c45c4502e26cb0f823e2/files/lib32 does not exist
F: Disallowing ipc access
F: Disallowing network access
F: Не заменять "/root/.local/share/flatpak" на tmpfs: Не удалось открыть путь "/root/.local/share/flatpak": Нет такого файла или каталога
F: Running /app/bin/apply_extra
F: Skipping parental controls check for app/com.spotify.Client/x86_64/stable due to running as root
F: running triggers from /usr/share/flatpak/triggers
F: running trigger desktop-database.trigger
F: Running 'bwrap --unshare-ipc --unshare-net --unshare-pid --ro-bind / / --proc /proc --dev /dev --bind /var/lib/flatpak /var/lib/flatpak -- /usr/share/flatpak/triggers/desktop-database.trigger /var/lib/flatpak'
F: running trigger gtk-icon-cache.trigger
F: Running 'bwrap --unshare-ipc --unshare-net --unshare-pid --ro-bind / / --proc /proc --dev /dev --bind /var/lib/flatpak /var/lib/flatpak -- /usr/share/flatpak/triggers/gtk-icon-cache.trigger /var/lib/flatpak'
F: running trigger mime-database.trigger
F: Running 'bwrap --unshare-ipc --unshare-net --unshare-pid --ro-bind / / --proc /proc --dev /dev --bind /var/lib/flatpak /var/lib/flatpak -- /usr/share/flatpak/triggers/mime-database.trigger /var/lib/flatpak'
Установка завершена.
Устанавливается пакет… Готово
Проверяется установка…
Проверяется установка… ОК
Операции после установки…
Операции после установки… Готово
Регистрируется приложения… ОК
Обновляется кэш системы…
Обновляется кэш системы… Готово
Завершается установка…
Установка успешно завершена :-)
#3 2025-10-14 16:07
What desktop profile did you apply upon installation ?
#4 2025-10-14 17:06
Q4OS Basic
qreport.tar.gz
#5 2025-10-14 20:04
We can't reproduce in VM. Fresh Q4OS Trinity installation, Basic proile + Spotify flatpak works as expected. Try:
$ flatpak repair
$ flatpak update
#6 2025-10-14 20:14
No, that does not help. Spotify still does not runing. Here is the video: https://drive.google.com/file/d/1J519HU … sp=sharing
#7 2025-10-15 08:09
We are investigating this issue. Please create a snapshot profile of your system, see https://www.q4os.org/dqa016.html#boome and post the profile file here, so we can apply it on the test system and perform some more testing.
#8 2025-10-15 11:51
Here is my profile snapshot:
Denis_Profile.qdprrc
#9 2025-10-15 13:07
Well, now we are able to reproduce the issue time by time. Investigation continues, we will post back later.
By the way, you need to rename the profile file not to contain capital letters to be able to import it in the Desktop profiler. It's Q4OS bug, we are working on a fix.
#10 2025-10-15 14:52
You can get rid of "failed to load module xapp-gtk3-module" message, if you uninstall "libxapp-gtk3-module liblibxapp1" packages. You can also try to install "apparmor" package and see what happens. But this doesn't workaround this issue completely.
Our conclusion is that this is not Q4OS bug. We can reproduce it on both VM and a real hardware machines on a plain Debian/Trinity installations. It looks like this Spotify flatpak release has some memory leaks so it crashes intermittently. It gets worse on a real hardware, so it may be connected to video drivers or video acceleration somehow. Unfortunately we are not able to fix this issue as it's an upstream one. Waiting for Spotify to update may or may not help.
In anyway you could also remove this Spotify flatpak installation and try to follow another way https://wiki.debian.org/spotify
#11 2025-10-15 15:07
Oh, I see. Luckily, Spotify is not critical application for me. So I will look for alternative. Thank you for your support!
#12 2025-10-18 16:35
We have released new testing Spotify installer for Q4OS. Although it's testing, you should be safe to install it, see https://www.q4os.org/forum/viewtopic.php?id=3624
#13 2025-10-18 20:46
Thank you, but even after installing Spotify using your new installer, it still refuses to run.
Returns an error: Invalid instruction
https://drive.google.com/file/d/15U0E5u … sp=sharing
#14 2025-10-18 21:41
This new installer completely avoids the flatpak version, as it installs Spotify from the native Linux repositories. This confirms that Linux version of Spotify suffers from memory leaks, in dependence on hardware. Overall, this version performed much better during our testing. Thanks for the feedback.
#15 2025-11-19 06:40
NoahWaverly
Thanks for the clarification! I’ll stick with the native installer for now and keep an eye out for future updates from Spotify that might fix the Flatpak version.
#16 2025-11-19 11:42
I will suggest you to search for Spotify alternatives. It can be a long waiting.
https://www.androidauthority.com/spotif … s-3601982/
https://www.reddit.com/r/spotify/commen … o_spotify/
