#1 2025-10-11 19:36
marek
Broadcom BCM43142 problems - broadcom-sta-common/dkms not working
Hi! does anyone know how to get broadcom BCM43142 running?
Have installed both broadcom-sta-common and broadcom-sta-dkms but to no avail, and 'fatal: module wl not found in directory' appears every time i try to run sudo modprobe wl.
Looks like it's not building properly.
Thanks in advance!
#2 2025-10-11 20:54
Re: Broadcom BCM43142 problems - broadcom-sta-common/dkms not working
try disabling secure boot options in BIOS?
#3 2025-10-11 20:57
marek
Secure Boot is disabled, just double-checked. It's set to boot in Legacy not UEFI
#4 2025-10-11 21:00
marek
HP Stream 11-d023tu if that helps
#5 2025-10-11 21:02
Try setting to uefi. Also disable legacy option rom if it's listed
#6 2025-10-11 21:03
marek
Thanks, will do so.
Will reinstall as UEFI too and get back.
#7 2025-10-11 21:08
Before that, you might want to run
sudo apt install --reinstall bcmwl-kernel-source
sudo modprobe -rv bcma
sudo modprobe -v wl
Reboot if needed
If this works out then you'd not have to reinstall
Edit: you might want to look at this and this (ignore the irrelevant portion as it op here had boot issues as well)
#8 2025-10-11 21:45
marek
sudo modprobe -v wl
Reboot if needed
Did these commands on the new install because the driver still isn't working even with UEFI, and apparently it can't find bcmwl-kernel source, and the 2nd modprobe command brings up the 'FATAL: Module wl not found in directory' error again.
Will try the solutions in the posts you linked too thanks
#9 2025-10-11 22:04
Seems like this package isn't available in plain debian, hence not in Q4OS either
Try reinstalling broadcom-sta-common and broadcom-sta-dkms
#10 2025-10-11 22:32
@marek
You only need to install "linux-headers-amd64" package. Now run in terminal:
$ sudo apt --reinstall install linux-headers-amd64 broadcom-sta-common broadcom-sta-dkms
It will build the broadcom kernel modules for you.
We don't recommend to build or install modules from other source than vanilla Debian as suggested above.
See also https://wiki.debian.org/wl
#11 2025-10-12 01:23
marek
@marek
Thank you so much!
Now this is why I use Q4OS smile
#12 2025-10-12 01:26
marek
@marek
This fixed it, I'm curious though, why are there only a handful of wireless networks available and all have (RSN) beside the name?
#13 2025-10-12 08:02
RSN = Robust Security Network.
About 10 years ago new security standards were introduced to counter the weaknesses in the old WEP key system. The problem with WEP was that it was a non-standard standard - if you get my drift - and had a number of weaknesses.
It took a long time for RSN specification to be agreed by the IEEE group and so in the meantime the Wifi Alliance came up with WPA - which is a bit like RSN but without some of the bells and whistles which caused the delay in the first place.
If you want to know more I suggest you do a bit if digging with your favourite search engine.
#14 2025-10-12 12:52
marek
Ah thanks!
