#26 2025-10-07 08:21
itsoulos
Re: Install problems in Dell precision with Nvidia
Update: Even though I have installed the nvidia driver in the kde system info appears only the integrated graphics card
See the image in the URL
http://itsoulos.teiep.gr/info.png
#27 2025-10-07 08:34
What is the output of command
$ inxi -G
#28 2025-10-07 08:37
itsoulos
$ inxi -G
Graphics:
  Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] driver: i915 v: kernel
  Device-2: NVIDIA AD107GL [RTX 2000 / 2000E Ada Generation] driver: nvidia
    v: 550.163.01
  Device-3: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
    type: USB
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 driver: X:
    loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa dri: iris
    gpu: i915,nvidia resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: iris,kms_swrast,nvidia,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.163.01
    renderer: NVIDIA RTX 2000 Ada Generation/PCIe/SSE2
  API: Vulkan v: 1.4.309 drivers: intel,llvmpipe surfaces: xcb,xlib
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
    de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
    wl: wayland-info x11: xdriinfo, xdpyinfo, xprop, xrandr
#29 2025-10-07 08:45
KDE info center seems to be incorrect.
#30 2025-10-07 08:48
itsoulos
How can I determine what driver is being used ? Is there any other command?
#31 2025-10-07 08:50
Try to run "nvidia-settings" from the main menu, if it sees your NVidia card the driver is in use.
#32 2025-10-07 08:58
itsoulos
Yes, the nvidia-settings is loaded and I think that is in use. Thank you very much. Although, the minor glitches with the mouse clicks remain and I think that is probably a KDE 6 problem or a compositor problem. I will have a look later. Thank you again.
#33 2025-10-07 09:08
itsoulos wrote:
... minor glitches with the mouse clicks  ...
We can't reproduce this issue. First, you should run "htop" in terminal and check if your system is overloaded for some reason. We would also try another mouse. If the issue persists, it would be better to open another topic.
#34 2025-10-23 20:04
itsoulos
I have many messages in dmesg as shown in the following paste link
https://pastebin.com/VZ4K40Wa
is there any problem ?
#35 2025-10-24 10:13
Yes, it looks like you are experiencing the Debian bug https://bugs-devel.debian.org/cgi-bin/b … ug=1107887 . Unfortunately we have no fix or workaround at the moment. You could try to install updated driver directly from Nvidia resources, read:
https://www.reddit.com/r/debian/comment … tdown_and/
https://developer.nvidia.com/cuda-downl … ion=Debian
#36 2025-10-24 10:52
itsoulos
Hence, should I use the following commands?
sudo apt install linux-headers-amd64 build-essential dkms
sudo apt install nvidia-driver
sudo dkms autoinstall
sudo update-initramfs -u -k all
#37 2025-10-24 10:55
We are not sure if this will solve the problem, but you can try it.
#38 2025-10-24 10:56
itsoulos
Also, I have found the following github
https://github.com/devleonardoamaral/de … -installer
that offers a full automatic installation
I will use it later and I will report the results
#39 2025-10-24 11:01
That looks nice. Reporting the result would be appreciated, thanks smile
#40 2025-10-24 16:04
itsoulos
Here are the steps for anyone has the same problems
1) wget https://developer.download.nvidia.com/c … -1_all.deb
2) sudo dpkg -i cuda-keyring_1.1-1_all.deb
3) sudo apt-get update
4)  sudo apt install cuda-drivers
Also, I had to remove the free drivers of nvidia before the previous steps
Thank you very much again
