#1 2025-09-28 07:13
itsoulos
Conky problems
Hello all,
I can not use any conky theme in Q4os Linux. Every time I add a theme two conky windows appeared on the screen.
One one the left with information on black and one on the right with the selected theme.
Any help?
Best regards
#2 2025-09-28 07:35
itsoulos
Re: Conky problems
itsoulos wrote:
Hello all,
Any help?
Best regards
And here is a link to the screen
http://itsoulos.teiep.gr/conky.png
#3 2025-09-28 08:56
Re: Conky problems
How do you add Conky themes to your desktop ? Exact step by step please.
#4 2025-09-28 09:02
itsoulos
Re: Conky problems
I have installed conky-manager2 from here https://launchpad.net/~ubuntuhandbook1/ … _amd64.deb  and I have downloaded some themes from MX. Subsequently, I opened the conky manager and I select one theme. When the system reboots two themes appeared on the screen as the screenshot in the related URL that I have sent you
#5 2025-09-28 09:11
Re: Conky problems
We'll check, but the sources you downloaded aren't compatible with Debian and Q4OS. So, it's to be expected that they won't work properly. Why not use Conky from the Debian repositories?
#6 2025-09-28 09:13
itsoulos
Re: Conky problems
Thank you one more time! I will download some themes from other sources, but I think that I had similar issues
#7 2025-09-28 09:37
Re: Conky problems
Why not use Conky from the Debian repositories ?
#8 2025-09-28 09:43
itsoulos
Re: Conky problems
How can I do that? I have followed every method that I have found in the internet and always two conky windows appear on my screen.
Is there a proper way from debian to start a custom conky theme automatically when I login to kde?
#9 2025-09-28 09:50
Re: Conky problems
$ sudo apt install conky-all
#10 2025-09-28 09:52
itsoulos
Re: Conky problems
I have done this. How can I add themes ? The only theme is a black window that appears on the left
#11 2025-09-28 12:09
itsoulos
Re: Conky problems
The only solution found so far is to copy the Conky Resource file to ~/.conkyrc  and reboot
#12 2025-09-29 19:48
Re: Conky problems
Maybe it's worth reading this, for example: https://itsfoss.com/conky-gui-ubuntu-13 … mmand-line
