#1 2025-09-25 21:24
Lotfi
Delete profile
Hello,
I'm new to this forum. I installed Q4OS (Plasma)  about six months ago, and a few days ago I also upgraded to the new Andromeda version. I'm very happy with it and not really inclined to change distributions for the moment. After using Lmde for two or three years, I think I'll be staying here for a while.
I just have a small question that I can't find an answer to. To test it out, I installed the Cinnamon profile. I'm not very satisfied with it, so I decided to uninstall it, but I can't figure out how. When I go to the profile manager, it doesn't give me the option to select Cinnamon. Is there a way to do this?
Thanks for everything in any case.
#2 2025-09-25 21:28
Re: Delete profile
Welcome to the forum smile
If you want to unintall Cinnamon, run in terminal:
$ sudo apt autoremove cinnamon cinnamon-core cinnamon-l10n
#3 2025-09-26 12:18
Lotfi
Re: Delete profile
Works perfect. Thanks a lot.
