#1 2025-09-21 22:59
[Upstream] Kicker broken in Q4OS 6 Trinity when Animation is turned on
Just installed Q4OS 6 and it's pretty cool~
After turning on panel hiding animation, it doesn't show up anymore even when cursor is moved to bottom of screen
(Hide mode: immediately)
Works fine when panel animation is turned off
Also icon for kmix is missing I think in waterleaf n waterleaf dark, it's using the fallback icon
#2 2025-09-22 09:55
Re: [Upstream] Kicker broken in Q4OS 6 Trinity when Animation is turned on
theasmitkid wrote:
After turning on panel hiding animation, it doesn't show up anymore even when cursor is moved to bottom of screen ... Works fine when panel animation is turned of
We can confirm this issue. It's easily reproducible on the plain Debian/Trinity stable installation, so we consider it the Trinity upstream one. We will check for possible fix.
theasmitkid wrote:
... icon for kmix is missing I think in waterleaf n waterleaf dark, it's using the fallback icon
Yes, we can confirm. We address this one for fix.
#3 2025-09-24 03:27
micheleCQ4OS
Hi, TDE dev here. Could you share the exact steps to reproduce this in a clean VM installation?
#4 2025-09-24 06:42
Hey Michele, thanks for coming here
Here's a theme I made, by default it has panel animation on so panel breaks when this theme is enabled
https://www.q4os.org/forum/viewtopic.ph … 070#p32070
#5 2025-09-24 07:35
Hi @micheleCQ4OS smile
- Install Trinity stable on Debian stable as per https://wiki.trinitydesktop.org/Debian_ … structions.
- Right click on the panel > configure panel > hiding > check hide automatically > check animate hiding
- Panel doesn't show up on mouse attempts once hidden
#6 2025-09-25 04:39
micheleCQ4OS
@Q4OS Team: thanks, I can now reproduce it on my machine too. The issue seems to be wit the "animate hiding" checkbox. If you unchecked that, the hiding works fine. Will try to have a look at this for R14.1.6 (not R14.1.5).
