#1 2025-09-22 20:03
Bernalg
How to disable the browser request 'Default keyring'?
Hi,
I have just installed Andromeda yesterday and since then every time I open Brave browser it asks me to open the wallet Default keyring.
Thanks in advance
#2 2025-09-22 20:05
Re: How to disable the browser request 'Default keyring'?
What DE ? Plasma, Trinity, other ? How did you install Brave ?
#3 2025-09-22 20:13
Bernalg
I use Trinity, and I installed Brave by following these steps mentioned in the official brave page:
sudo apt install curl
sudo curl -fsSLo /usr/share/keyrings/brave-browser-archive-keyring.gpg https://brave-browser-apt-release.s3.br … eyring.gpg
sudo curl -fsSLo /etc/apt/sources.list.d/brave-browser-release.sources https://brave-browser-apt-release.s3.br … er.sources
sudo apt update
sudo apt install brave-browser
https://brave.com/linux/
I also installed Brave using the installer included, but it did not show the icon and it also asked me for the wallet default keyrig, so I deleted it.
#4 2025-09-22 20:25
You may only need to install kwallet6 package. Nonetheless, we recommend you to install Brave from the Software center and re-login into the desktop session. Brave icon shows up in the start menu as usual.
#5 2025-09-22 20:36
Bernalg
Thank you, it's better now!
