#1 2016-03-21 12:59
Q4OS Orion 1.4.8 released
It's the maintenance release of the Q4OS 1.4 'Orion' series based on the most recent Debian Jessie packages. Bunch of more or less important bug fixes, packages updates and security patches has been delivered.
#2 2016-03-22 17:37
Re: Q4OS Orion 1.4.8 released
And my ping bug is gone too, Thanks q4os team smile
#3 2016-03-23 19:23
crosscourt wrote:
So far looks fine.
Hello crosscourt!
I have read somewhere in forum, that you prefer i686pae versions instead of x64 because of lower RAM usage.
So, if I have 4GB of RAM and CPU which supports AMD64 architecture, is it better to use i686pae version on it? Will i686pae version utilize all my 4GB of RAM and two CPU cores?
http://ark.intel.com/products/74749/Int … e-3_00-GHz
#4 2016-03-24 19:00
Crosscourt, congratulations for 777 post in this Forum!!!
And what browser is integrated in Q4OS 1.4.8 i686pae instead of Google Chrome?
#5 2016-03-24 19:39
Chromium 49.0.2623.87
#6 2016-03-25 17:58
crosscourt wrote:
Thanks Rademes and Chromium works very well and is a good replacement for Chrome for 32bit users.
Then I will use it more frequently, since I will move to Q4OS i686pae soon.
