#1 2025-08-21 07:34
Taige
Wine and Window games/programs
I read Wine's faq on how to start a windows program.
The instructions say:
Because Windows programs will often look for files in the location they were started from, when using the command line you should start them in a very specific way: "change directory" to the folder where the program is located and run the .exe file using only its filename. For example:
$ cd '.wine/drive_c/Games/Tron'
$ wine tron.exe
This command line works if the program/game is in an ssd with a Fat32 or Ntfs partition, right?
#2 2025-08-21 08:57
Re: Wine and Window games/programs
Yep, you can run apps that are in NTFS or fat32 partitions
For most programs it is recommended to cd to the program's directory and run the program
cd /userdata/Apps/Portable/Windows
wine tron.exe
(I mount my NTFS partition as /userdata to store most of the data I wanna access across the operating systems)
in a note, theasmitkid wrote:
But make sure your wine prefixes are installed in an ext4 partition otherwise it won't work
Also do not try to use your windows installation as a wine prefix, it would corrupt your windows installation
#3 2025-08-21 17:27
Taige
wine tron.exe
Thank you!
[Bot] ClaudeBot
