#1 2025-08-15 14:47
Konsole: unexpected behaviour of Alt + (alt-code)
In another thread Armbroke complained about not being able to type the pipe | char.
Before advising him to type Alt+124, I tried myself and I was surprised to get this displayed on a new line instead:
(arg: 124)
After having typed the '4', nothing happens and "(arg: 124)" remains displayed.
If I hit enter or tab or right arrow at that time, the whole line is replaced by a new prompt.
I can type up to 6 digits and at the 7th, the whole line is also replaced by a new prompt.
This behaviour is the same with Q4OS 5 as with Q4OS 4.
In a pure console (Alt+Ctrl+F2) it works as expected.
I spent a long time searching the web how to use Alt+(alt-code) in Konsole but in vain. And I wasn't able to find any setting in Konsole to configure that.
Does anybody know what this (arg: ...) is used for and how to enable the usual usage of alt-codes?
Edit:
laptop, keyboard layout = "be"
#2 2025-08-15 17:17
Re: Konsole: unexpected behaviour of Alt + (alt-code)
Perhaps it would be a good idea if you were to provide a link to the thread in question.
Try man readline. The alt key plus number is kicking off a numeric argument (arg).
#3 2025-08-15 19:10
I believe its this thread bin,  www.q4os.org/forum/viewtopic.php?id=5575
#4 2025-08-15 20:03
Thanks for your replies.
crosscourt is right; more precisely post #15.
I browsed readline man, but I wasn't able to find anything about this behaviour nor why KDE Konsole and a pure console behave differently.
#5 2025-08-15 22:02
As far as we know, Plasma Konsole can't handle Windows-style Alt+Num keyboard shortcuts, while Linux console does. We are not sure why.
#6 2025-08-15 23:47
Thanks for the information. It will avoid me to spend time searching further.
#7 2025-08-24 06:24
bugmenot
i was thinking the style to type unicode in linux is different,it is not alt + num like in windows, try ctrl+shift+u then type unicode like ctrl+shift+u 1f602 then space
surprised that alt + num is working in real linux consoles but not trinity or plasma konsole, don't know why, may be i will try in gnome terminal
i hope some body reply to my topics btw
#8 2025-08-24 08:52
Thanks for your suggestion. Unfortunately it works neither in Plasma Konsole, nor even in a pure terminal.
I think there is a difference because Plasma "Konsole" is not a real console (or terminal), it is an emulator with a graphical interface that "looks like" a real console (dark background and monospace font), but having its own "interpretation" of keystrokes, and obviously Alt + (alt-code) is not implemented.
