#1 2025-08-08 15:36
Q4OS 6 R11 Testing Beta - tderandrtray not autostarting
Installed with basic profile.
Normally when you launch tderandrtray you are prompted whether it should autostart in future.
In this release it is not happening. This is confirmed in ~/.trinity/share/config/tderandrtrayrc which shows as false even after configuring global profile.
On an alpha 9 machine this shows as true as it should when the prompt is given a positive response - however in this beta there is no prompt.
#2 2025-08-09 09:22
Re: Q4OS 6 R11 Testing Beta - tderandrtray not autostarting
We will take a look, thanks.
#3 2025-08-10 06:55
Re-installed and it seems to be working OK now!!!!
Testing eh????
Sorry to have troubled you.
#4 2025-08-10 10:14
No problem, reporting is appreciated.
