#1 2025-06-16 15:04
Durhammer
Command to launch TDE Classic menu? [SOLVED]
I'm fiddling around in IceWM and while I am prepared to configure and use jgmenu, is there a way to invoke the TDE Classic menu from a command that can be put into a tint2 panel?
Thanks in advance.
#2 2025-06-16 17:01
Re: Command to launch TDE Classic menu? [SOLVED]
It's not the way we can recommend. You can't launch the menu itself, but TDE panel:
$ /opt/trinity/bin/kicker
right click on the panel > unlock > right click on the start menu > switch to classic menu
Expect that really weird things may happen and likely they will happen.
#3 2025-06-16 17:51
Durhammer
Thanks. My olde customized jgmenu is usably working. Need to tweak it, but working.
