Is it possible to fully uninstall and/or prevent KATE from Autostarting to the Tray area?
Sincerely /PxDemaR - Respect the Elderly & Honor Knowledge! - 60+ Viking Swede living in Netherlands! PTSD & ADD - Music Production & Graphic Creator - ROCK-RABBIT-STUDIO NPA © 2002 – 2026 - Game Squad-Manager “VETERAN VIKINGS” [X10] © 2006 – 2026
Welcome to the forum
What Q4OS version and what desktop are you using ?
KDE Plasma
Run in termianl:
$ sudo apt autoremove kate
and reboot
Thanks mate! But KATE still starts a Tray icon and also stays in the Start Menu. However, the program cannot be started, as it says that the software is uninstalled.
What if you right click on the icon in systray ?
Yes, it shows KATE Sessions, but of course nothing can be started. It's really weird that KATE also stays in the Start menu.
So go to system settings > autostart and remove kate shortcut from autostarting
Back in 5
It's not there. Submitting Screenshot...
You can safely remove 50frst-rsession script as it's useless and reboot. Plasma may keep trying open the script with Kate. Post back the result.
Sure do. Thanks!
Nope.. still in Tray and Start Menu. Did a file search on KATE, and there are still many directories and files left. Submitting 2 Screenshots.
Would you post a screenshot of kate in tray ? What happens if you left/right-click on the icon ?
If you install Kate again, run it and disable systray actions:
Open Kate and navigate to Settings > Configure Kate.
Go to the Application tab.
In the Window section, locate the Minimize to System Tray option.
Disable this option.
Hover just say Kate Sessions. Click is on the screenshot.
I really appreciate you taking the time to help.
So install Kate again, run it and disable systray actions:
Reboot and see if still sitting in systray
Okay... back soon!
I discovered that KATE has 2 applications, a regular and a Plasma Desktop version (see picture). I had both installed. The Plasma version is probably included with the Q4 installation, which I missed, and also installed the regular one. The Plasma version was still installed after your assistance, which you couldn't know. Both are uninstalled now. But and the icon in the Tray bar is gone, but the icon in the Start Menu is still stuck. When I right-click and request Edit Application, I get the window in the 2nd picture. So still a bit wonky.
Since Kate was a stock item in plasma, when you uninstall it will will remain this link so its a one click reinstall or install if it wasn't installed in the first place. You actually have to remove the .desktop file out of /usr/share/applications if you don't want the one click installer in the applications menu.
I'll look at it tonight, when I get home, but that should be the path on a plasma install.
Alright! Thanks mate!
Appreciated your time. 5 Star support!
no problem I am VPN to my network at the house, but I don't have my computer on so I can't see it on my Q4os install
