#1 2025-06-09 23:08
Durhammer
How to restore TDE menu with a "frequently used" app list [SOLVED]
I've been working out other TDE issues with @q4osteam and others and after changing the appearance and themes and such, I lost my previous tweak of the menu setup where there were 5 or more slots above the "Search" box (which is useless, at least to me) where the most-launched apps showed up as a substitute "Favorites" menu. How do I get that back?
I opened up the TDE Menu Editor, and nothing there suggests how to accomplish this. Ditto for the Menu Editor in the Help.
Lost in menu-land....
EDIT: SOLVED -- see next page.
#2 2025-06-10 10:54
Re: How to restore TDE menu with a "frequently used" app list [SOLVED]
Is it the "classic" TDE menu ?
You may need to switch to the "categories" menu structure > wecome screen > switch start menu > classic + categories.
Next right click on panel > configure panel > menus > quickstart menu items > max number of entries
#3 2025-06-10 16:04
Durhammer
Thanks! But...ummm...why is this sort of "hidden" by being put on the welcome screen and not a part of the menu configuration itself, or exposed somewhere in the control panel? Strange!
#4 2025-06-10 16:28
That might be, we will consider a change.
