#1 2025-05-19 00:06
BaDaHe
Firefox does not always behave as it should
I am pleased to be an ex-Linux Mint and new-ish (two months) convert to Q4OS.
From day one I have noticed that Firefox does not always behave as it should.
I acknowledge that Chromium is the Q4OS default browser, but I am a very long time Firefox user and Chrome is Google, and I want them out of my life.
I have experienced several occasions when there are buttons on web pages that need to be clicked, but when I do so absolutely nothing happens.
And in the same vein, there should have been a button to be clicked, but it was not there!
Using Konqueror on those occasions has got me through, but not today when trying to use the Australia Post web site.
I keep my computer up-to-date. My version of Firefox in use today is 128.10.1esr (64-bit).
I searched the forum, but did not find similar reports of Firefox peculiarities. Surely I can't be the only person experiencing this?
BaDaHe
NSW Australia
Mon 19-May-25  09:06
#2 2025-05-19 00:44
Re: Firefox does not always behave as it should
I havent had any issues with Firefox at all and Ive got close to 20 systems running with it. Maybe instead of the ESR version you should try the standard version and see if that helps. Im in quite a few forums and honestly havent heard any issues such as you describe.
Which version of Q4OS are you using and what type of hardware?  Have you had this issue with any other browser assuming youve tried any other browsers.
If it occurs in more than Firefox it could be a system issue.
Turning off hardware acceleration in Firefox performance settings(in general section, go to performance settings, unclick performance setting box, youll see hardware accel unclick that box) many times will help with some issues.
Welcome to the forums!  smile
#3 2025-05-19 09:22
Welcome smile
You have installed Firefox ESR apparently. We would recommend you to install and use Firefox release from the Q4OS software center, version 138.0.4 at the moment.
Please post an example of such a page with direct link so we could test it. A screenshot of the proper page layout would be helpful too.
#4 2025-05-19 18:40
I run Firefox most recent version of ESR and it doesnt have any issues such as mentioned above.
#5 2025-05-20 07:28
I have used ESR for - well I cannot remember how long, it's been that long.
Never seen the kind of issue you describe.
Just checked the Australia Post web site and it seems to be absolutely fine. Actually better than the Royal Mail site here in the UK.
When you migrated over from Mint - I assume the Ubuntu 2x.x.series - did you copy over your ~/.mozilla profile folder or have you started from scratch with ESR?
If I get funny browser issues my first action is to rename ~/.mozilla to ~/.mozilla.old and then start Firefox. That will create a completely new config file.
If you still have the same problem then it will be down to something else.
We don't know anything about your machine so it would help if you could open Konsole and run
inxi -Fxxxmprz
and copy paste back the results.
#6 2025-06-02 04:01
BaDaHe
Quick responses, thank you. And slow responses from me because I have unexpectedly been away from home.
Q4OS only offered me the FlatPak version of Firefox from the Discover Software Centre. No thank you. I am aware that I am swimming upstream, that FlatPak is touted as the future, but I can’t see the benefits for me. It only appears to be better for the developers who supply a massive download for every Linux version, while providing no automatic update facility. There will be other opinions, and I am not wanting to start a fight.
Having installed Synaptic, I then searched for Firefox and was offered Firefox-ESR (which I had never used, or even heard of). Since from Linux Mint I was used to be using whatever Synaptic offers, I did not think twice before installation.
Following the suggestions from CROSSCOURT and Q4OSTEAM I deleted it using Synaptic. Using the information at:    https://support.mozilla.org/en-US/kb/in … efox-linux   I followed the INSTALL FIREFOX .DEB PACKAGE FOR DEBIAN-BASED DISTRIBUTIONS (RECOMMENDED) instructions and Firefox 139.0.1 (64-bit) is now installed.
Perhaps I am now back on track. We’ll see! For the time being this issue can be marked as RESOLVED.
Regards
BdH
from the land down under
Mon 2-Jun-25  13:01
As requested by BIN...
inxi -Fxxxmprz
System:
Kernel: 6.1.0-37-amd64 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
   Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 7 dm: SDDM
   Distro: Q4OS 5.8.1-n1 base: Debian GNU/Linux 12 (bookworm)
Machine:
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: PRIME B760M-K v: Rev 1.xx
   serial: <superuser required> UEFI: American Megatrends v: 1805
   date: 10/30/2024
Memory:
RAM: total: 31.06 GiB used: 5.77 GiB (18.6%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
   required.
CPU:
Info: 12-core (8-mt/4-st) model: 12th Gen Intel Core i7-12700 bits: 64
   type: MST AMCP smt: enabled arch: Alder Lake rev: 2 cache: L1: 1024 KiB
   L2: 12 MiB L3: 25 MiB
Speed (MHz): avg: 808 high: 900 min/max: 800/4800:4900:3600 cores: 1: 800
   2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 900 10: 854 11: 816
   12: 800 13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
   bogomips: 84480
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel AlderLake-S GT1 vendor: ASUSTeK driver: i915 v: kernel
   ports: active: HDMI-A-1 empty: DP-1 bus-ID: 0000:00:02.0 chip-ID: 8086:4680
   class-ID: 0300
Device-2: AMD Cayman LE GL [FirePro V5900] vendor: Dell driver: radeon
   v: kernel arch: TeraScale-3 ports: active: DP-2 empty: DP-3,DVI-I-1
   bus-ID: 0000:01:00.0 chip-ID: 1002:6707 class-ID: 0300
Device-3: Logitech HD Pro Webcam C920 type: USB
   driver: snd-usb-audio,uvcvideo bus-ID: 1-4.3.1:9 chip-ID: 046d:082d
   class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.7 compositor: kwin_x11 driver: X:
   loaded: modesetting,radeon unloaded: fbdev,vesa dri: iris gpu: i915,radeon
   display-ID: :0 screens: 1
Screen-1: 0 s-res: 4640x1920 s-dpi: 96 s-size: 1227x508mm (48.31x20.00")
   s-diag: 1328mm (52.28")
Monitor-1: DP-2 mapped: DisplayPort-1-1 pos: right model: Dell U2410
   serial: <filter> res: 1200x1920 hz: 60 dpi: 94
   size: 324x518mm (12.76x20.39") diag: 611mm (24.1") modes: max: 1920x1200
   min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: Dell U3415W
   serial: <filter> res: 3440x1440 hz: 60 dpi: 109
   size: 798x335mm (31.42x13.19") diag: 865mm (34.1") modes: max: 3440x1440
   min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel UHD Graphics 770
   (ADL-S GT1) direct-render: Yes
Audio:
Device-1: Intel Raptor Lake High Definition Audio vendor: ASUSTeK
   driver: snd_hda_intel v: kernel bus-ID: 1-4.3.1:9 bus-ID: 0000:00:1f.3
   chip-ID: 046d:082d class-ID: 0102 chip-ID: 8086:7a50 serial: <filter>
   class-ID: 0403
Device-2: AMD Cayman/Antilles HDMI Audio [Radeon HD 6930/6950/6970/6990]
   vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1
   chip-ID: 1002:aa80 class-ID: 0403
API: ALSA v: k6.1.0-37-amd64 status: kernel-api
Network:
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
   port: 4000 bus-ID: 0000:03:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek 802.11ac WLAN Adapter type: USB driver: N/A
   bus-ID: 1-4.1.2:10 chip-ID: 0bda:b832 class-ID: 0000 serial: <filter>
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
   v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Drives:
Local Storage: total: 7.57 TiB used: 2.26 TiB (29.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
   size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
   rev: 2B2QEXM7 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
   rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
ID-3: /dev/sda vendor: Toshiba model: DT01ACA300 size: 2.73 TiB
   speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: ABX0 scheme: GPT
ID-4: /dev/sdb vendor: Western Digital model: WD30EZRX-00DC0B0
   size: 2.73 TiB speed: 6.0 Gb/s type: N/A serial: <filter> rev: 0A80
   scheme: GPT
ID-5: /dev/sdc type: USB vendor: Seagate model: ST9320325AS
   size: 298.09 GiB type: HDD rpm: 5400 serial: <filter> rev: 102F scheme: MBR
Partition:
ID-1: / size: 146.59 GiB used: 12.96 GiB (8.8%) fs: ext4 dev: /dev/nvme1n1p2
ID-2: /boot/efi size: 511 MiB used: 5.9 MiB (1.1%) fs: vfat
   dev: /dev/nvme1n1p1
ID-3: /home size: 146.59 GiB used: 73.04 GiB (49.8%) fs: ext4
   dev: /dev/nvme1n1p3
ID-4: /media/badahe/300GBPretty size: 292.35 GiB used: 114.78 GiB (39.3%)
   fs: ext4 dev: /dev/sdc1
ID-5: /mnt/Backup-3TB size: 2.69 TiB used: 1.04 TiB (38.9%) fs: ext4
   dev: /dev/sda1
ID-6: /mnt/Data-3TB size: 2.69 TiB used: 1018.41 GiB (37.0%) fs: ext4
   dev: /dev/sdb1
ID-7: /mnt/Data-625GB size: 614.13 GiB used: 28 KiB (0.0%) fs: ext4
   dev: /dev/nvme1n1p5
ID-8: /mnt/Data-750GB size: 686.64 GiB used: 28 KiB (0.0%) fs: ext4
   dev: /dev/nvme0n1p2
ID-9: /mnt/TIMESHIFT size: 228.12 GiB used: 28.08 GiB (12.3%) fs: ext4
   dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: partition size: 6 GiB used: 252 KiB (0.0%) priority: -2
   dev: /dev/nvme1n1p4
Sensors:
System Temperatures: cpu: 27.0 C mobo: N/A gpu: radeon temp: 49.0 C
Fan Speeds (RPM): N/A
Repos:
Packages: pm: dpkg pkgs: 2438
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/10_q4os.list
   1: deb http://q4os.org/q4repo q4os-5-0-cn main
Active apt repos in: /etc/apt/sources.list.d/20_debian.list
   1: deb http://deb.debian.org/debian/ bookworm main contrib non-free non-free-firmware
   2: deb http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware
   3: deb http://deb.debian.org/debian/ bookworm-updates main contrib non-free non-free-firmware
No active apt repos in: /etc/apt/sources.list.d/30_debian_backports.list
Active apt repos in: /etc/apt/sources.list.d/mozilla.list
   1: deb [signed-by=/etc/apt/keyrings/packages.mozilla.org.asc] https://packages.mozilla.org/apt mozilla main
Active apt repos in: /etc/apt/sources.list.d/signal-xenial.list
   1: deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt xenial main
Info:
Processes: 370 Uptime: 2d 3h 47m wakeups: 30 Init: systemd v: 252
target: graphical (5) default: graphical Compilers: gcc: 12.2.0 alt: 12
Shell: Bash v: 5.2.15 running-in: konsole inxi: 3.3.26
#7 2025-06-02 09:14
We would recommend you to remove Flatpak from your system, so no Flatpak apps will be suggested by any package manager:
$ sudo apt --purge autoremove flatpak
Yes, it's a way to install FF release on your system. However if you install it from the Q4OS Software center as we recommended, you would achieve the same more easily. No Flatpak version ofcourse.
We can also recommend you to apply the Basic profile upon the next Q4OS installation, so you get Flatpak free system prepared to install additional end user applications like Firefox. As soon as you settle up with your setup, get Snapshot profile, so you can apply it on future installations. See Desktop profiler documentation https://www.q4os.org/dqa016.html
#8 2025-06-02 13:13
BaDaHe
Thank you   sudo apt --purge autoremove flatpak    applied.
BaDaHe
Mon 2-Jun-25  22:12
Oz
