Hello, is there anyway to disable the yellowing(changing background color to #f5f6be) of the search bar(location toolbar) in Konqueror, as it conflicts with the dark theme on TDE?
In result, there is white text on a yellow background - which is not readable to me, and the solution of changing the color of the whole system text color doesn't makes sense of the dark theme.
This porblem also appearing in some places on konqueror, where such thing is using.
Q4OS 5.8
Visual TDE theme: Darkonair
Yes, we can confirm a bug in Darkonaire theme. It's registered and addressed to be fixed. Thanks for reporting.
We have prepared a fix for this issue. It will become public in the next TDE update for Q4OS.
Okay, thank you so much)
This porblem also appearing in some places on konqueror, where such thing is using.Q4OS 5.8
Is there a way to stop Konqueror (on TDE) from turning the search/location bar background yellow (#f5f6be), which clashes with dark themes and makes white text unreadable? I’d prefer not to alter the entire system’s text color just to fix this—it defeats the purpose of using a dark theme.
No, it's not possible at the moment as the color is hardwired in the TDE code. Nonetheless we have prepared a fix for this issue. It will become public in the next TDE update for Q4OS.
