#1 2025-04-12 17:53
fabio8v
After install Q4 it is impossible boot windows
Hi
my disk has 1 partition windows 2025 server, 1 partition ntfs, 1 partition fat32 (here I wish to install Q4 and I did it) but at the boot appears only Q4, can you help me?
#2 2025-04-13 09:42
Re: After install Q4 it is impossible boot windows
What way did you install Q4OS ?
Does your PC have an EFI bootloader?
You may only need to edit "/etc/default/grub" and set "GRUB_DISABLE_OS_PROBER" to "false". Thereafter run in terminal:
$ sudo update-grub
and reboot. Windows should be shown in the boot table.
You could also select the default boot entry in EFI BIOS.
#3 2025-04-13 14:30
fabio8v
Thank you for replay, my bios is legacy, on the /etc.... is already setting as you wrote....
#4 2025-04-14 17:14
fabio8v
well, I risolved.. change from true to false
#5 2025-04-14 20:30
... set "GRUB_DISABLE_OS_PROBER" to "true".
Oh "false" indeed, that was mistake, sorry for that. Fixed in the post in question.
