#1 2025-04-13 23:15
Networkcore
How to transfer files from Q4OS Trinity 64-bit to an Android phone?
It turns out that when I'm using Q4OS Trinity 64-bit and I try to transfer a file to my phone, I get this message: "Writing camera is not supported." Any solution?
I've already tried using gmtp and nothing happened.
#2 2025-04-14 06:40
Re: How to transfer files from Q4OS Trinity 64-bit to an Android phone?
#3 2025-04-14 12:23
Thank you, i needed that too, but
Attach your device via USB cable, set it as MTP device ...
how can i do the latter?
#4 2025-04-14 13:11
@FlexQ4: You may want to check this...
https://www.howtogeek.com/192732/androi … s-storage/
