#1 2025-04-08 23:05
josek
Energy manager problem
I installed Trinity Q40s but I can't find the battery options..
Why does my screen freeze after hibernation or hybrid sleep?
I would also like to reduce the swap file because it is 8GB and I would like to go down to 2GB.
I would appreciate some help ?
#2 2025-04-09 09:23
Re: Energy manager problem
Do you have an external drive attached? Maybe the system tries to resume from it rather from the internal drive. That's what happened here.
#3 2025-04-09 11:40
System tray > Tde powersave icon
#4 2025-04-09 17:42
josek
I don't have an external drive, just my laptop's SSD, I suspect it might be my Nvidia card drivers.
By the way, I already solved it by deleting the swap partition with the Gpart app.
I found the Tde powersave icon, but I can't find anything to remove hybrid sleep or hibernation.
Is there any way to do this from the terminal?
#5 2025-04-10 09:49
josek
problem solved
