#1 2016-03-10 08:17
bobby
TQt database plug-in (TQSQLITE3) not seen by Krecipes-trinity
Hi Q4OS Team,
I am swapping out all my KDE 3x apps for trinity apps.  K3b-trinity works excellent but, I have a SQLite plug-in issue with Krecipes-trinity.
Error:  TQt database plug-in (TQSQLITE3) is not installed but, libqt4-sql-sqlite (SQLite 3 plugin for Qt 4)  & libqt4-sql-sqlite2 (SQLite 2 plugin for Qt 4) ARE INSTALLED.
Do I need to add a path to plugin ?  or install another plugin package ?  or Uninstall and reinstall plugins ?
Thanks,
Bobby
No Longer Using Q4OS
#2 2016-03-10 08:34
bobby
Re: TQt database plug-in (TQSQLITE3) not seen by Krecipes-trinity
[SOLVED]
I installed packages--: libtq3-mt-sqlite && libtq3-mt-sqlite3   / SQLite3 plugin for TQt
