Hi all,
I would like to manually add a Menu Link / Icon under Programs Menu.
What /opt/trinity file do I need to modify ?
Thanks for your help,
Bobby
No Longer Using Q4OS
I think you can add a .desktop file in /usr/share/applications/ if it has the relevant information in the file it should get added to the right menu(s). Not too sure though, I think there is probably an easier way, I just don't know it (yet) ![]()
Dai
@Dai,
Thanks. I'll look in .desktop and see what I can figure out.
Bobby
http://www.q4os.org/dqa011.html#desktop.2
Yes, correct.
@Q4OS Team, Thank You for link & feedback.
