#1 2025-02-26 03:19
jim
'reminders' program by Sasha Hale
can 'reminders' program by Sasha Hale be installed on Q4OS? The website I found only offers a way to use flatpak, and it doesn't seem to work with Q4OS, or is there a way to get it installed?
thanks, jim
#2 2025-02-26 03:39
jim
Re: 'reminders' program by Sasha Hale
Apologies, I now see I can install flatpak using synaptic. I certainly don't have to correct picture, but I think of flatpak as a resource heavy item, if that's sort of right, could I use it to install reminders, and then delete all or at least all the other program material that I wouldn't need?
thanks from an extreme newbie, jim
#3 2025-02-26 04:09
You didnt mention what version of Q4OS you use, KDE/TDE?  You can install Reminders using Discover after you enable the Flatpak option in settings.  In TDE , look here for instructions,  www.q4os.org/forum/viewtopic.php?id=5013
I wouldnt delete anything as you may run into issues given the nature of Flatpak. The devs may be able to advise you further about these actions.
Welcome to the forums!  smile
#4 2025-02-26 09:38
@jim
We would recommend you to install Sasha Hale reminders from Flathub https://flathub.org/apps/collection/dev … a%20Hale/1 . Don't remove Flatpak package after this action, it doesn't load the system too much.
If you have an other option how to install on Debian, please provide a link.
#5 2025-02-26 17:47
Just a quick note, I run Q4OS 5.7 KDE and have Flathub enabled in Discover, and Reminders is openly available to install as a Flatpak.
