#1 2025-02-24 06:58
BalkL
Windows_10 desktop environment. Need help redesigning the login screen
Hello,
I work a lot with this Q4OS system and I really like it.
I would like to customize it even more for Windows 10.
Simply because I like the interface.
I got the Windows_10 desktop environment from the Q4OS team. I tried to redesign the login screen of this.
The reason is that what I found installable startup screen would be this: win10-sddm-theme /birbkeks/
Well, it's full of bugs.
In the original package from the Q4OS team, I solved almost everything. I changed the wallpaper, moved the clock and calendar to the bottom left corner, the avatar image to a larger one, the login form to white, the username in larger letters.
The only exception is the bottom buttons, they cannot be moved to the bottom right corner. I cannot put them there. The buttons are in the Main.qml file.
Can anyone help me with this?
Thank you very much in advance.
#2 2025-02-24 10:22
Re: Windows_10 desktop environment. Need help redesigning the login screen
At this point we don't know how to move the buttons, but we can check the QML code and post back. Is it possible to get the code of the modifications you used?
#3 2025-02-24 10:57
BalkL
Of course, as soon as I get home from work, I pack it up and send it off. Although in our last email correspondence we talked about a github account, I did it, but using it is still a bit incomprehensible to me. So I'll either email it or post it here on the forum.
#4 2025-02-26 11:05
We received the code via e-mail, thanks. We will examine it as we have some time and post back. It would be pretty helpful, if you would create a new Github project with this code, so we can contribute into it.
#5 2025-02-28 19:10
BalkL
Please do not burden yourselves with checking the codes. Throw it away, because in my opinion it's not very good. And I think the background image is also copyrighted.
Now I'm trying to make a completely new solution that bypasses this copyright issue, with similar but free to use images, and for any issues that might be controversial, I'll just incorporate elements that are free to use.
I'll put it on github and ask for testing here on the forum as soon as it's ready.
#6 2025-02-28 19:30
Great idea, so we could contribute.
