#1 2025-02-19 01:25
KennyW
Terminal can't find Q4OS package manager
Hi Guys,
New here, so just finding my way around. I'd like to make a live Q4OS USB to be able to try out the distro on a few old computers being thrown out at work, to see if they can be of use. But when I go to load the imager from the terminal as advised on page one of 'Tips & Tricks' page using the command:
sudo apt install q4os-imager
I just get the response:
Reading package lists... Done
Building dependency tree
E: Unable to locate package q4os-imager
I am working in Linux Mint, Mate version on my home PC. Any help greatly appreciated.
#2 2025-02-19 01:51
Re: Terminal can't find Q4OS package manager
Look here,  www.q4os.org/dqa018.html
Youll notice that at the end of that thread in tips and tutorials, someone else is having the same issue as you did above.
#3 2025-02-19 08:03
The "q4os-imager" package exists only in Q4OS repositories,  not in other distro's ones.
You can find other instructions here: https://wiki.debian.org/DebianInstall#C … Flashdrive
You can also search the web with these keywords: "write iso to usb with dd". dd is a command available from a terminal. It comes with nearly all distro installs.
Here are good explanations and instructions: https://pendrivelinux.com/create-bootab … -using-dd/
Whatever the app you use to write an .iso to a drive, the operation is irrecoverable, so "It’s crucial to double or triple check the target device before executing the command."
#4 2025-02-19 20:57
The link I posted above in #2 is from the Q4OS documentation that shows how to accomplish the task in Windows, other Linux distros and Q4OS.
