#1 2025-01-25 18:13
Raf47485077
Tar.XZ. files
hello everyone. I need to install the Tor browser and I downloaded a file with the tar.xz extension for my 32-bit machine. How is it installed? With what commands? I couldn't find anything online. Thanks to those who answer me.
#2 2025-01-25 19:01
Re: Tar.XZ. files
We would recommend you to install the Debian way, see https://wiki.debian.org/TorBrowser
#3 2025-02-01 18:17
VegaLinuxQ4
Re: Tar.XZ. files
Extract the file use Ark or p7zip, locate the extracted folder - open in terminal - do as app's intruction to install (e.g ./install.sh)
Or if you have no idea, check youtube there are plenty video will guide u how to
#4 2025-02-01 19:53
Re: Tar.XZ. files
Theres a Flatpak app called Tor browser launcher that will help you download, install and keep updated the Tor browser.
The same app is available in Synaptic package manager if you prefer.
