#1 2025-01-26 16:08
A simple way to compile mpv by myself?
Hi,
corresponding to this post: https://www.q4os.org/forum/viewtopic.php?id=5162
if i've grabed the sources of mpv (eg. this version: https://github.com/mpv-player/mpv/archi … 3.1.tar.gz ), unpacked it to a folder, and installed meson (build system): Is there a simple way then to compile/make a local version of mpv?
How would i look like?
Thank you
#2 2025-01-26 23:21
Re: A simple way to compile mpv by myself?
it seems, that i have to "enable source repositories" - How can i do this, does anybody here know a tutorial?
#3 2025-01-27 09:45
You need to edit file /etc/apt/sources.list.d/20_debian.list , and enable "deb" lines begging with "#" character so they will look like this:
deb-src http://deb.debian.org/debian/ bullseye main contrib non-free
#4 2025-01-27 11:04
deb-src http://deb.debian.org/debian/ bookworm main contrib non-free non-free-firmware
Just to be safe, since i'm still on 4.12/Gemini: bookworm - not bullseye?
#5 2025-01-27 11:06
Yes, excuse for the blunder. You just need to enable all the commented "deb-src" lines, but keep "bullseye" anywhere. We have fixed the post in question.
#6 2025-01-27 13:31
Thank you! And it's good to see, that there are *.save copies of each repo files already present!
Do you have an idea, if (beside meson/ninja build systems) i have to fetch also "git" via Synaptic?
There are build scripts for mpv here: https://github.com/mpv-player/mpv-build
Important is: i want to build a version of mpv only locally (in my developement folder).
I do not want to change /usr/bin/mpv or any of the current libraries of my system at all! (god beware! wink)
#7 2025-01-27 14:31
You likely need to install git:
$ sudo apt install git
or install it via Synaptic, it's essentially the same.
#8 2025-02-02 16:41
Hello,
trying to install git (via Synaptic) i got these errors:
W: Die Datei »http://security.debian.org/debian-security/pool/updates/main/g/git/git-man_2.30.2-1%2bdeb11u3_all.deb« konnte nicht heruntergeladen werden
  404  Not Found [IP: 146.75.118.132 80]
W: Die Datei »http://security.debian.org/debian-security/pool/updates/main/g/git/git_2.30.2-1%2bdeb11u3_amd64.deb« konnte nicht heruntergeladen werden
So i had to: sudo apt-get update  first...
Now, after i did Install 'some basic packaging tools' with the command: > apt-get install devscripts equivs
i tried > mk-build-deps -s sudo -i  (as described here: https://github.com/mpv-player/mpv-build … tu-package ) but it doesn't work:
-> Usage:
    mk-build-deps --help|--version
    mk-build-deps <options> control file | package name ...
hmmmm...
