#1 2025-01-01 20:29
q4osusermn
Q4OS for Windows; installed OK, but locks up after login screen
Hello all; my 1st post and, unfortunately, a troublesome issue.
Installed Q4OS for Windows into Windows 7 on my old EMachines PC.  Install seemed to go OK, although it took awhile.  Finally said finished, and I initiated auto reboot.  Got to the first screen in Q4OS; it asked about my video settings, then locked up.  Rebooted and went through routine to get to Q4OS login window.  Logged in, hit "enter", and a screen with 3 large dots, a comma-shaped icon and a moving gearwheel appeared; gearwheel turned a couple of times, stopped, then nothing; waited a bit, then hit "enter" again, but still nothing.  Tried latter procedure several times with same result.
Anyone else experienced this and resolved it?
Thanks.
