I was motivated to work on this because systemd constantly irritated me with slow boot ups and system shutdowns. There are some issues with this install (note the comments!)
Devuan KDE guided install with separate /home directory and runit:
Comment out CD in /etc/apt/sources.list
If directories are lacking:
$ xdg-user-dirs-update
There were no sub-directories in my /home directory after first boot. My system could not achieve a graphical interface, probably as my computer has an Nvidia card, but I don't believe that the nouveau driver loaded either. So, I downloaded and installed the q4os script:
$ wget q4os.org/downloads/q4os-setup.sh
$ su (or sudo -s)
# sh q4os-setup.sh
Run the following after reboot to confirm running init system:
$ cat /proc/1/comm
runit is currently running on my system.
Current status is that while I have a running runit system, /var/log/boot contains the following error message:
"Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon failed!"
which could be why Discovery doesn't appear to be able to access a wired internet connection. Synaptic works fine.
When trying to install Nvidia drivers on a previous Devuan install (sysv init), dpkg exited with a #1 error. I as of yet have not installed the Nvidia drivers as I am trying to avoid the dpkg error again. It will be interesting to see how long I can do that... As a side note, the q4os system has yet to prompt me to install Nvidia drivers like it usually does... (The computer has an NVIDIA TU116 [GeForce GTX 1660 SUPER] gpu.)
I’ve had a perfectly wonderful evening, but this wasn’t it. - Groucho Marx
Here is a more in depth look at the resulting system after running the q4os script on a Devuan KDE runit install:
$ ps ax | grep run
1 ? Ss 0:00 runit
1542 ? Ss 0:00 runsvdir -P /etc/service log: .....................................................................................................................................................................................................................................................................................................................................check: 3: socklog-check: not found check: 3: socklog-check: not found
1593 ? S 0:00 /usr/sbin/smartd --pidfile /var/run/smartd.pid
1685 ? Ss 0:00 runsv getty-tty4
1686 ? Ss 0:00 runsv cups
1687 ? Ss 0:00 runsv getty-ttyS0
1688 ? Ss 0:00 runsv dbus
1689 ? Ss 0:00 runsv dhclient
1690 ? Ss 0:00 runsv getty-tty3
1691 ? Ss 0:00 runsv anacron
1692 ? Ss 0:00 runsv cron
1693 ? Ss 0:00 runsv sddm
1694 ? Ss 0:00 runsv acpid
1695 ? Ss 0:00 runsv elogind
1696 ? Ss 0:00 runsv getty-tty6
1697 ? Ss 0:00 runsv getty-tty5
1698 ? Ss 0:00 runsv rsyslog
1699 ? Ss 0:00 runsv dbus.dep-fixer
1700 ? Ss 0:00 runsv getty-tty2
1701 ? Ss 0:00 runsv default-syslog
1702 ? Ss 0:00 runsv getty-tty1
1706 ? S 0:00 svlogd -tt -b 2048 /var/log/runit/dbus
1709 ? S 0:00 svlogd -tt -b 2048 /var/log/runit/sddm
1712 ? S 0:00 svlogd -tt -b 2048 /var/log/runit/dhclient
1716 ? S 0:00 svlogd -tt -b 2048 /var/log/runit/anacron
1719 ? S 0:00 svlogd -tt /var/log/runit/acpid
1919 ? S 0:00 avahi-daemon: running [host_computer.local]
1924 tty7 Ssl+ 0:00 /usr/lib/xorg/Xorg -nolisten tcp -auth /var/run/sddm/{5bc3cb32-6e3c-4fe0-ae1b-8f42736e3c47} -background none -noreset -displayfd 17 -seat seat0 vt7
1980 ? S 0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
2112 ? S 0:00 /usr/lib/x86_64-linux-gnu/sddm/sddm-helper --socket /tmp/sddm-auth5d07c714-2378-448c-b18f-637ebc26e64d --id 1 --start /usr/lib/x86_64-linux-gnu/libexec/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user brian
2117 tty8 Ss+ 0:00 dbus-run-session /usr/bin/startplasma-wayland
2142 tty8 Sl+ 0:03 /usr/bin/kwin_wayland --wayland-fd 7 --socket wayland-0 --xwayland-fd 8 --xwayland-fd 9 --xwayland-display :1 --xwayland-xauthority /run/user/1000/xauth_AViBbU --xwayland
2163 tty8 Sl+ 0:00 /usr/bin/Xwayland :1 -auth /run/user/1000/xauth_AViBbU -listenfd 49 -listenfd 50 -displayfd 41 -rootless -wm 44
2328 tty8 S+ 0:00 /usr/bin/dbus-daemon --config-file=/usr/share/defaults/at-spi2/accessibility.conf --nofork --print-address 11 --address=unix:path=/run/user/1000/at-spi/bus_1
2644 tty8 Sl+ 0:00 /usr/lib/x86_64-linux-gnu/libexec/baloorunner
2782 ? Ss 0:00 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
3993 pts/1 S+ 0:00 grep run
/etc/runit$ ls -1F runsvdir
current@
default/
default.run/
single/
solo/
svmanaged/
/etc/runit$ ls -1F runsvdir/default
acpid@
anacron@
cron@
cups@
dbus@
dbus.dep-fixer@
default-syslog@
dhclient@
elogind@
getty-tty1@
getty-tty2@
getty-tty3@
getty-tty4@
getty-tty5@
getty-tty6@
getty-ttyS0@
rsyslog@
sddm@
$ ls -F /etc/init.d
acpid* cups-browsed* mountkernfs.sh* saned*
alsa-utils* dbus* mountnfs-bootclean.sh* sddm*
anacron* elogind* mountnfs.sh* seatd*
apparmor* eudev* networking* sendsigs*
avahi-daemon* gdomap* network-manager* single*
bluetooth* halt* openntpd smartmontools*
bootlogd* hostname.sh* procps* speech-dispatcher
bootlogs* hwclock.sh* pulseaudio-enable-autospawn* stop-bootlogd*
bootmisc.sh* keyboard-setup.sh* rc@ stop-bootlogd-single*
brightness* killprocs* rc.local* sudo*
checkfs.sh* kmod* rcS@ umountfs*
checkroot-bootclean.sh* lm-sensors* README@ umountnfs.sh*
checkroot.sh* mountall-bootclean.sh* reboot* umountroot*
console-setup.sh* mountall.sh* rmnologin* unattended-upgrades*
cron* mount-configfs* rsync* urandom*
cups* mountdevsubfs.sh* rsyslog* x11-common*
avahi-daemon is clearly running, so something else must be preventing Discover from accessing the internet...
