#1 2024-12-24 03:23
shingi345
Falkon Crashes
Clean install of TDE, whenever I use Falkon it crashes basically right when I open the browser. I'm on a 32 bit laptop, but I have an SSD and yeah, Firefox even runs ok. But I need something lighter for a smoother experience. Ideas on the crashing? If not Falkon, any recommendations? Love Q4OS. Thanks for your help!
#2 2024-12-24 12:10
Re: Falkon Crashes
If you didn't install Falkon from the Software Centre, uninstall it, reinstall it from there and see what happens.
#3 2024-12-24 12:58
Re: Falkon Crashes
We are not able to reproduce the issue. Falkon works as expected on our testing 32bit machine. Please run Falkon from terminal:
$ falkon
and post its output.
#4 2024-12-24 15:06
shingi345
Re: Falkon Crashes
shingi345@q4os-desktop:~$ falkon
Falkon: 1 extensions loaded
Segmentation fault (core dumped)
Yes, it is the version from the software center.
#5 2024-12-25 07:55
Re: Falkon Crashes
Disable the extension and try again from terminal - what extension is this?
#6 2024-12-25 16:50
shingi345
Re: Falkon Crashes
Falkon comes stock with Adblock. That’s all there is
#7 2024-12-26 11:26
Re: Falkon Crashes
A segmentation fault is typical of an issue while trying to access memory. It can be caused by a bug in the program, which is not likely here. So maybe there is a problem with your RAM. I suggest you to make a memory test.
1. Install memtest86+:
`$ sudo apt update && sudo apt install memtest86+`
2. Reboot and wait for the GRUB menu, then choose the option to run memtest86:
it runs tests continuously, each run takes a long time (tens of minutes) and displays a big "PASS" if successful; let it make at least 3 runs.
3. Hit Esc to quit and reboot.
The output of `$ inxi -Fxxx` could give some useful info too.
#8 2024-12-27 18:09
shingi345
Re: Falkon Crashes
3 passes, no errors
#9 2024-12-27 18:10
shingi345
Re: Falkon Crashes
And disabling Adblock didn’t change anything. Still crashed.
#10 2024-12-27 19:49
Re: Falkon Crashes
What is the output of `$ inxi -Fxxx`?
You could create a new user and use that new account to test Falkon again.
If it still crashes, boot from a live media, install Falkon and test again.
I also found an old post (2019) on a forum mentioning that installing nvidia driver solved the problem. You could try that in the live session if you have such a chip (inxi output).
