#1 2024-12-14 16:17
globetrotterdk
Windows installer - Audio devices suddenly disappeared.
After booting the system again, I suddenly no longer have any audio devices detected (and of course) no sound. This looks like the way the system was before I installed the pipewire-audio package on the system, right after Windows install...
I’ve had a perfectly wonderful evening, but this wasn’t it. - Groucho Marx
#2 2024-12-14 21:07
globetrotterdk
Re: Windows installer - Audio devices suddenly disappeared.
Hmm, after rebooting a couple of times, things started working again. Unfortunately, I just rebooted again, and no audio devices are listed (and no sound). This problem seems to be intermittent, but consistent.
#3 2024-12-15 12:18
You should not have pipewire and pulseaudio installed side by side, they may conflict with each other. The default audio system for Aquarius is pulseaudio. If you want to replace it, you should uninstall the pulsaudio completely.
#4 2024-12-16 12:58
globetrotterdk
Pulseaudio was uninstalled when I installed the pipewire-audio package on the system.
