#1 2024-11-20 18:50
pisauitab
Unable to login on Q4OS with Trinity
Hello,
I have installed Q4OS on my virtual machine, and whenever I try to login with the (correct) credentials I set for my user, the screen becomes black and I am sent back to the login screen.
My virtual machine is using around 2GB of ram, 2 processors, and has 7 GB of storage.
All other posts I saw of people having this issue ended inconclusively. Is there a solution?
I will post the outputs of any commands if needed.
#2 2024-11-20 19:03
pisauitab
Re: Unable to login on Q4OS with Trinity
after running inxi -Fxxx I noticed almost 100% of the storage was being used. I am trying to check if installing with more disk space will fix it.
#3 2024-11-20 19:10
pisauitab
Well, That seemed to be the issue... Should have guessed...
