#1 2024-11-13 22:16
matematico65
Issue: updatemgr.exu crashes with SIGSEGV during updates
Hello,
I’m experiencing an issue with the Q4OS update manager on my system.
Every time there is an available update, I receive an error indicating that updatemgr.exu has crashed with a segmentation fault (SIGSEGV, signal 11).
Here are the details:
    Error Message: "Unknown application updatemgr.exu crashed and caused signal 11 (SIGSEGV)"
    System Version: Q4OS 5.0 (based on Debian Bookworm)
    Error Frequency: This crash occurs consistently each time I attempt to use the graphical update manager.
    Workaround: I’m able to update manually via terminal without any issues using sudo apt update && sudo apt upgrade. The problem seems specific to the graphical interface or updatemgr.exu itself.
Thank you very much for your support.
#2 2024-11-13 23:48
Re: Issue: updatemgr.exu crashes with SIGSEGV during updates
Yes, we can confirm this bug on certain Q4OS systems. We will address it, thanks for reporting.
