#1 2024-09-26 17:52
abhishek10
Regarding Tux Paint and other software in Discover App store
Today i completely uninstall flatpak and flatpak installed apps. previously i used tux paint using flatpak version. but after uninstall flatpak i do not found tux paint in discover app store. how to find all Debian Packages in Discover App Store. Please Help. I am New Linux User..
#2 2024-09-26 18:09
Re: Regarding Tux Paint and other software in Discover App store
A tip to find a package in the repositories if you don't know its exact name (use * as wildcards):
$ apt list *tux*
#3 2024-09-26 18:13
abhishek10
Can i use synaptic package manager in Q4OS KDE ? can installing any software with the synaptic package manager cause any problem in Q4OS KDE Version.?
#4 2024-09-26 20:22
Yes, you can use Synaptic in Plasma. It's very convenient package manager, it will show and serve to install all the available deb packages from repositories.
#5 2024-10-20 09:32
Dimitrydevan
Hey, You can try searching for Debian packages in the terminal using `apt search tuxpaint`. Good luck!
#6 2024-10-20 18:03
Just open up Synaptic package manager, click on search and type tux paint. Its very easy to use and I use it most of the time.
Its much more reliable than Discover and youll generally find that youll have far fewer issues using it versus Discover.
