#1 2024-10-17 09:30
MH
Installation process interupted
Hi
, i have downloaded the Aquarius winSetup.ece to install Aquarius on my HP Elitebook laptop running under Windows 10, The prog5ram download Aquarius but almost at the end of the installation process I get an error message error executing command >>command =C:\windows\sysnative\bcdedit.exe /copy(bootmgr) /d QAOS Aquarius ,,,,,, Element not found
afterwards to installation process ends
What can I do. I am new to linux and I wanted to try it alongside my windows 10
Thanks for helping
Michael
#2 2024-10-17 10:16
Re: Installation process interupted
The error message may mean:
- Some security software blocks registering the Q4OS record in Windows boot manager
- EFI data inconsistency
We would need to get a debug information to be able to investigate the issue. Please attach the following logfile:
c:\users\<username>\appdata\local\temp\wubi-5.x-rev344.log
What partition or disk drive letter do you attempt to install Q4OS to ?
#3 2024-10-17 14:25
MH
Thanks for your quick reply. Unfortunately I did not save the log file. I had tried to install Q4OS on drive D.. I will retry the installation this evening  . I get back online when I have the log file
