#1 2024-09-05 16:54
justlostintime
Lost screen resolution in 5-5
Computer: Gateway profile 3
Have been running an older version of the os for a long time at 1024x768 auto detected.
With the new update  q4os-5.5-i386-instcd.r1.iso
It seems to think it only support 640x480 and 800x600 resolutions. So I guess it no longer correctly
detects the screen on my device. I am rather disappointed.
I have been using your software for years on these little devices, and yes they still get used.
Does anyone have any Idea how to get the full resolution back?
Thanks
#2 2024-09-05 18:15
Re: Lost screen resolution in 5-5
You can still use an older supported version Q4OS 4 Gemini, download https://www.q4os.org/downloads3.html
#3 2024-09-07 19:06
You'll need to use the older Q4OS 4 version as the Intel GMA 950 has many issues with more recent Linux distros.
