#1 2024-08-25 04:58
hcy1
Unable to search for Wi-Fi
I have install Q4OS on my Macbook Air successfully. Everything works well except that the system can't search for Wi-Fi connection. When I went to settings to check the Wi-Fi, it showed that the laptop have been connected to a wired connection called "lo".
When I tried to install the corresponding NIC driver, it indicated the system had installed the NIC driver.
#2 2024-08-25 08:01
Re: Unable to search for Wi-Fi
"lo" is a connection called "loopback" to your computer itself, with 127.0.0.1 as IP address. If you have a web server (apache for example) running on your machine you can type 127.0.0.1 in the address bar of a web browser to get your home page.
  • Which version of Q4OS and which desktop do you use?
  • How did you check the Wi-Fi? Did you use the network icon in the taskbar?
  • What is the output of $ sudo rfkill? (install rfkill if it is not present: $ sudo apt install rfkill).
  • It could be useful to have the output of $ inxi -Fxxx (type all the commands having $ in a Konsole, without the $ sign).
#3 2024-08-26 02:10
hcy1
:~$ sudo rfkill
[sudo]  的密码:ID TYPE      DEVICE      SOFT      HARD
0 bluetooth hci0   unblocked unblocked
System:
Host: macbookair72 Kernel: 6.1.0-23-amd64 arch: x86_64 bits: 64
    compiler: gcc v: 12.2.0 Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.8
Network:
  Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
    driver: bcma-pci-bridge v: N/A pcie: speed: 2.5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
As shown above, the computer I am using is a MacBook Air 7,2 and the network card model is a Broadcom BCM4360.
#4 2024-08-26 10:29
Your wireless adapter may work with newer kernel, so we recommend you to try install kernel from Debian backports:
- Add Debian backports repo:
$ sudo qrepoadd --gui
and run installation:
$ qinst-kernel-bpo
#5 2024-08-26 10:45
I see that rfkill shows only a Bluetooth device, but no wlan (= Wi-Fi) device, blocked or unblocked.
