I attempted to install q4os-winsetup-5.5-r1.1.zip on to a SATA drive from Windows 10. I got the following error message when trying to boot after install. (see attachment) Strange thing is older versions worked fine, just this version seems to be a problem. Disabling secure boot makes no difference.
Side note, I noticed q4os windows setup does not like nvme drives, might have something to do with intel controller, not sure.
Q4OS for Win supports secure boot, so you don't need to disable it.
Did older version work on that same machine ?
What version exactly, would you specify, so we can find a difference ?
The error looks like Debian kernel doesn't have some drivers for the hardware in question. Q4OS uses just the default Debian kernel.
... I noticed q4os windows setup does not like nvme drives ...
Why do you think so ?
Q4OS supports NVME disks, however it varies by hardware, would you post an error message and NVME device specs, so we can investigate please ?
We have successfully tested the setup on multiple machines with NVME disks.
Regarding the nvme issue:
Got the following error message when using nvme drive. "Invalid argument Host filesystem not found, make Windows partition accessible" No error with sata drive. Windows 10 is installed on nvme drive, maybe q4os does not being installed along side windows?
Others have had similar issue
https://www.q4os.org/forum/viewtopic.php?id=4687
https://www.q4os.org/forum/viewtopic.php?id=3728
I got 5.4 to work with sata drive. For some reason 5.5 is giving me problems. Same machine. The only difference is I switched to a new wireless adapter.
The OP's issue isn't most likely related to the NVME drive, as they are not the other links you listed above. Q4OS for Windows setup supports NVME drives, we did a few successful installs on such hardware.
We can see the message
.. ZSTD-compressed data is corrupt ..so would suspect some hardware problem. Did you try to reinstall Q4OS on that machine ? The wireless adapter type has no effect on the first boot stage.
The 5.5 version uses updated Debian kernel, so it could be a clue. In anyway thanks for reporting.
Did you try to reinstall Q4OS on that machine? The 5.5 version uses updated Debian kernel, so it could be a clue. .
Yes tried reinstall on same machine. Where is old versions of q4os for windows? Can't find on Sourceforge.
First make sure you have downloaded the latest Winsetup installer "q4os-winsetup-5.5-r1.1.zip" and check the MD5sum here https://www.q4os.org/downloads1.html . If you cannot install with the latest version, proceed with the older version, see below.
It's not available directly, however you can use it this way:
First download two files:
https://q4os.sourceforge.io/download/q4 … 5.4-r1.zip
https://sourceforge.net/projects/q4os/f … oop.img.xz
Unzip the zipped installer and run from windows "cmd" command prompt:
q4os-winsetup.exe --dimagepath=c:\full_path_to_the_image\q4os5b-x64-loop.img.xzFor more info about possible installer options please read https://github.com/hakuna-m/wubiuefi/wi … arameters-
See also https://github.com/hakuna-m/wubiuefi/wiki/FAQ
Paste a result here please.
Ok I got the ZSTD-compressed data is corrupt message to go away by disabling Windows Defender. But have run into new problems, error message says cannot find kernel now.
Attached is log.
08-09 13:23 INFO root: === wubi 5.x rev346 ===
08-09 13:23 DEBUG root: Logfile is c:\users\user\appdata\local\temp\wubi-5.x-rev346.log
08-09 13:23 DEBUG root: sys.argv = ['main.pyo', '--exefile="E:\\q4os-winsetup.exe"']
08-09 13:23 DEBUG CommonBackend: data_dir=C:\Users\User\AppData\Local\Temp\pyl2869.tmp\data
08-09 13:23 DEBUG WindowsBackend: 7z=C:\Users\User\AppData\Local\Temp\pyl2869.tmp\bin\7z.exe
08-09 13:23 DEBUG WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
08-09 13:23 DEBUG CommonBackend: Fetching basic info...
08-09 13:23 DEBUG CommonBackend: original_exe=E:\q4os-winsetup.exe
08-09 13:23 DEBUG CommonBackend: platform=win32
08-09 13:23 DEBUG CommonBackend: osname=nt
08-09 13:23 DEBUG CommonBackend: language=en_US
08-09 13:23 DEBUG CommonBackend: encoding=cp1252
08-09 13:23 DEBUG WindowsBackend: arch=amd64
08-09 13:23 DEBUG CommonBackend: Parsing isolist=C:\Users\User\AppData\Local\Temp\pyl2869.tmp\data\isolist.ini
08-09 13:23 DEBUG CommonBackend: Adding distro Q4OS Aquarius-i386
08-09 13:23 DEBUG CommonBackend: Adding distro Q4OS Aquarius-amd64
08-09 13:23 DEBUG WindowsBackend: Fetching host info...
08-09 13:23 DEBUG WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001
08-09 13:23 DEBUG WindowsBackend: windows version=vista
08-09 13:23 DEBUG WindowsBackend: windows_version2=Windows 10 Enterprise
08-09 13:23 DEBUG WindowsBackend: windows_sp=None
08-09 13:23 DEBUG WindowsBackend: windows_build=19045
08-09 13:23 DEBUG WindowsBackend: gmt=-5
08-09 13:23 DEBUG WindowsBackend: country=US
08-09 13:23 DEBUG WindowsBackend: timezone=America/New_York
08-09 13:23 DEBUG WindowsBackend: windows_username=User
08-09 13:23 DEBUG WindowsBackend: user_full_name=User
08-09 13:23 DEBUG WindowsBackend: user_directory=C:\Users\User
08-09 13:23 DEBUG WindowsBackend: windows_language_code=1033
08-09 13:23 DEBUG WindowsBackend: windows_language=English
08-09 13:23 DEBUG WindowsBackend: processor_name=Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
08-09 13:23 DEBUG WindowsBackend: bootloader=vista
08-09 13:23 DEBUG WindowsBackend: system_drive=Drive(C: hd 1656573.86328 mb free ntfs)
08-09 13:23 DEBUG WindowsBackend: drive=Drive(C: hd 1656573.86328 mb free ntfs)
08-09 13:23 DEBUG WindowsBackend: drive=Drive(D: cd 0.0 mb free )
08-09 13:23 DEBUG WindowsBackend: drive=Drive(E: hd 476501.785156 mb free ntfs)
08-09 13:23 DEBUG WindowsBackend: EFI boot = True
08-09 13:23 DEBUG WindowsBackend: uninstaller_path=None
08-09 13:23 DEBUG WindowsBackend: previous_target_dir=None
08-09 13:23 DEBUG WindowsBackend: previous_distro_name=None
08-09 13:23 DEBUG WindowsBackend: keyboard_id=67699721
08-09 13:23 DEBUG WindowsBackend: keyboard_layout=us
08-09 13:23 DEBUG WindowsBackend: keyboard_variant=
08-09 13:23 DEBUG CommonBackend: python locale=('en_US', 'cp1252')
08-09 13:23 DEBUG CommonBackend: locale=en_US.UTF-8
08-09 13:23 DEBUG WindowsBackend: total_memory_mb=2047.99999905
08-09 13:23 DEBUG CommonBackend: Searching for local ISOs
08-09 13:23 DEBUG CommonBackend: Searching for local CDs
08-09 13:23 DEBUG Distro: checking whether C:\Users\User\AppData\Local\Temp\pyl2869.tmp is a valid Q4OS Aquarius CD
08-09 13:23 DEBUG Distro: does not contain C:\Users\User\AppData\Local\Temp\pyl2869.tmp\install.386\install.bat
08-09 13:23 DEBUG Distro: does not contain C:\Users\User\AppData\Local\Temp\pyl2869.tmp\install.amd\install.bat
08-09 13:23 DEBUG Distro: checking whether D:\ is a valid Q4OS Aquarius CD
08-09 13:23 DEBUG Distro: dir does not exist
08-09 13:23 DEBUG Distro: checking whether E:\ is a valid Q4OS Aquarius CD
08-09 13:23 DEBUG Distro: does not contain E:\install.386\install.bat
08-09 13:23 DEBUG Distro: does not contain E:\install.amd\install.bat
08-09 13:23 DEBUG root: Previous target dir: None
08-09 13:23 INFO root: Running the installer...
08-09 13:23 DEBUG WindowsFrontend: __init__...
08-09 13:23 DEBUG WindowsFrontend: on_init...
08-09 13:23 INFO WinuiPage: appname=wubi, localedir=C:\Users\User\AppData\Local\Temp\pyl2869.tmp\translations, languages=['en_US', 'en']
08-09 13:23 DEBUG WinuiInstallationPage: target_drive=E:, installation_size=256000MB, distro_name=Q4OS Aquarius, language=en_US, locale=en_US.UTF-8, username=q4os
08-09 13:23 INFO root: Received settings
08-09 13:23 DEBUG TaskList: # Running tasklist...
08-09 13:23 DEBUG TaskList: ## Running select_target_dir...
08-09 13:23 INFO WindowsBackend: Installing into E:\Linux64\Debian12_S001
08-09 13:23 DEBUG TaskList: ## Finished select_target_dir
08-09 13:23 DEBUG TaskList: ## Running prepare_srcfiles...
08-09 13:23 DEBUG WindowsBackend: target hostdir: Linux64/Debian12_S001
08-09 13:23 DEBUG WindowsBackend: substituing in C:\Users\User\AppData\Local\Temp\pyl2869.tmp\winboot\wubildr.cfg : _dynsubst_host_wubidir_ >> Linux64/Debian12_S001
08-09 13:23 DEBUG WindowsBackend: substituing in C:\Users\User\AppData\Local\Temp\pyl2869.tmp\winboot\grub.firstboot.cfg : _dynsubst_host_wubidir_ >> Linux64/Debian12_S001
08-09 13:23 DEBUG WindowsBackend: substituing in C:\Users\User\AppData\Local\Temp\pyl2869.tmp\winboot\EFI\grub0efi.cfg : _dynsubst_host_wubidir_ >> Linux64/Debian12_S001
08-09 13:23 DEBUG WindowsBackend: substituing in C:\Users\User\AppData\Local\Temp\pyl2869.tmp\data\wubildr.cfg : _dynsubst_host_wubidir_ >> Linux64/Debian12_S001
08-09 13:23 DEBUG WindowsBackend: substituing in C:\Users\User\AppData\Local\Temp\pyl2869.tmp\data\wubildr-disk.cfg : _dynsubst_host_wubidir_ >> Linux64/Debian12_S001
08-09 13:23 DEBUG WindowsBackend: substituing in C:\Users\User\AppData\Local\Temp\pyl2869.tmp\data\menu.winboot : _dynsubst_host_wubidir_ >> Linux64/Debian12_S001
08-09 13:23 DEBUG WindowsBackend: substituing in C:\Users\User\AppData\Local\Temp\pyl2869.tmp\data\grub.firstboot.cfg : _dynsubst_host_wubidir_ >> Linux64/Debian12_S001
08-09 13:23 DEBUG TaskList: ## Finished prepare_srcfiles
08-09 13:23 DEBUG TaskList: ## Running create_dir_structure...
08-09 13:23 DEBUG CommonBackend: Creating dir E:\Linux64\Debian12_S001
08-09 13:23 DEBUG CommonBackend: Creating dir E:\Linux64\Debian12_S001\disks
08-09 13:23 DEBUG CommonBackend: Creating dir E:\Linux64\Debian12_S001\install
08-09 13:23 DEBUG CommonBackend: Creating dir E:\Linux64\Debian12_S001\install\boot
08-09 13:23 DEBUG CommonBackend: Creating dir E:\Linux64\Debian12_S001\disks\boot
08-09 13:23 DEBUG CommonBackend: Creating dir E:\Linux64\Debian12_S001\disks\boot\grub
08-09 13:23 DEBUG CommonBackend: Creating dir E:\Linux64\Debian12_S001\install\boot\grub
08-09 13:23 DEBUG TaskList: ## Finished create_dir_structure
08-09 13:23 DEBUG TaskList: ## Running create_uninstaller...
08-09 13:23 DEBUG WindowsBackend: Copying uninstaller E:\q4os-winsetup.exe -> E:\Linux64\Debian12_S001\uninstall-wubi.exe
08-09 13:23 DEBUG registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001 UninstallString E:\Linux64\Debian12_S001\uninstall-wubi.exe
08-09 13:23 DEBUG registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001 InstallationDir E:\Linux64\Debian12_S001
08-09 13:23 DEBUG registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001 DisplayName Q4OS Aquarius
08-09 13:23 DEBUG registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001 DisplayIcon E:\Linux64\Debian12_S001\Q4OS Aquarius.ico
08-09 13:23 DEBUG registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001 DisplayVersion 5.x-rev346
08-09 13:23 DEBUG registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001 Publisher Q4OS Aquarius
08-09 13:23 DEBUG registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001 URLInfoAbout https://q4os.org
08-09 13:23 DEBUG registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001 HelpLink http://www.ubuntu.com/support
08-09 13:23 DEBUG TaskList: ## Finished create_uninstaller
08-09 13:23 DEBUG TaskList: ## Running choose_disk_sizes...
08-09 13:23 DEBUG WindowsBackend: total size=256000
root=240000
swap=16000
home=0
usr=0
08-09 13:23 DEBUG TaskList: ## Finished choose_disk_sizes
08-09 13:23 DEBUG TaskList: ## Running create_preseed_diskimage...
08-09 13:23 DEBUG TaskList: ## Finished create_preseed_diskimage
08-09 13:23 DEBUG TaskList: ## Running get_diskimage...
08-09 13:23 DEBUG TaskList: New task download
08-09 13:23 DEBUG TaskList: ### Running download...
08-09 13:23 DEBUG downloader: downloading https://github.com/q4osteam/q4os-instal … oop.img.xz > E:\Linux64\Debian12_S001\disks\q4os5c-x64-loop.img.xz
08-09 13:23 DEBUG downloader: Download start filename=E:\Linux64\Debian12_S001\disks\q4os5c-x64-loop.img.xz, url=https://github.com/q4osteam/q4os-install-media/releases/download/v5/q4os5c-x64-loop.img.xz, basename=q4os5c-x64-loop.img.xz, length=1118322668, text=None
08-09 13:24 DEBUG downloader: download finished (read 31457280 bytes)
08-09 13:24 DEBUG TaskList: ### Finished download
08-09 13:24 DEBUG TaskList: ## Finished get_diskimage
08-09 13:24 DEBUG TaskList: ## Running extract_diskimage...
08-09 13:24 ERROR WindowsBackend: Error executing command
>>command=C:\Users\User\AppData\Local\Temp\pyl2869.tmp\bin\7z.exe e -i!q4os5c-x64-loop.img -oE:\Linux64\Debian12_S001\disks E:\Linux64\Debian12_S001\disks\q4os5c-x64-loop.img.xz
>>retval=2
>>stderr=
7-Zip 9.20 Copyright (c) 1999-2010 Igor Pavlov 2010-11-18
Processing archive: E:\Linux64\Debian12_S001\disks\q4os5c-x64-loop.img.xz
Extracting q4os5c-x64-loop.img Data Error
Sub items Errors: 1
>>stdout=
Traceback (most recent call last):
File "\lib\wubi\backends\win32\backend.py", line 503, in extract_diskimage
File "\lib\wubi\backends\common\utils.py", line 68, in run_command
Exception: Error executing command
>>retval=2
>>stderr=
Sub items Errors: 1
>>stdout=
08-09 13:24 DEBUG TaskList: ## Finished extract_diskimage
08-09 13:24 DEBUG TaskList: ## Running expand_diskimage...
>>command=C:\Users\User\AppData\Local\Temp\pyl2869.tmp\bin\resize2fs.exe -f E:\Linux64\Debian12_S001\disks\root.disk 240000M
>>retval=1
>>stderr=Resizing the filesystem on E:\Linux64\Debian12_S001\disks\root.disk to 61440000 (4k) blocks.
>>stdout=resize2fs 1.44.5 (15-Dec-2018)
/usr/bin/resize2fs: Block bitmap checksum does not match bitmap while trying to resize E:\Linux64\Debian12_S001\disks\root.disk
Please run 'e2fsck -fy E:\Linux64\Debian12_S001\disks\root.disk' to fix the filesystem
after the aborted resize operation.
08-09 13:24 DEBUG TaskList: ## Finished expand_diskimage
08-09 13:24 DEBUG TaskList: ## Running create_swap_diskimage...
08-09 13:24 DEBUG TaskList: ## Finished create_swap_diskimage
08-09 13:24 DEBUG TaskList: ## Running modify_bootloader...
08-09 13:24 DEBUG TaskList: New task modify_bcd
08-09 13:24 DEBUG TaskList: ### Running modify_bcd...
08-09 13:24 DEBUG WindowsBackend: modify_bcd Drive(C: hd 1656573.86328 mb free ntfs)
08-09 13:24 DEBUG WindowsBackend: EFI boot
08-09 13:24 DEBUG WindowsBackend: EFI boot partition \Device\HarddiskVolume4
08-09 13:24 DEBUG WindowsBackend: Temporary EFI drive H:
08-09 13:24 DEBUG WindowsBackend: Copying EFI folder C:\Users\User\AppData\Local\Temp\pyl2869.tmp\winboot\EFI -> H:\EFI\DebianBoot
08-09 13:24 DEBUG WindowsBackend: grubcfg destination folder H:\EFI\DebianBoot
08-09 13:24 DEBUG WindowsBackend: copying C:\Users\User\AppData\Local\Temp\pyl2869.tmp\winboot\EFI\grub0efi.cfg >> H:\EFI\DebianBoot\grub.cfg
08-09 13:24 DEBUG WindowsBackend: efi_arch=x64
08-09 13:24 DEBUG registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi_Debian12_S001 VistaBootDrive {535a1ee2-e0f3-11ee-914f-522b732020c4}
08-09 13:24 DEBUG TaskList: ### Finished modify_bcd
08-09 13:24 DEBUG WindowsBackend: modify_bcd Drive(E: hd 476501.785156 mb free ntfs)
08-09 13:24 DEBUG WindowsBackend: BCD has already been modified
08-09 13:24 DEBUG TaskList: ## Finished modify_bootloader
08-09 13:24 DEBUG TaskList: ## Running diskimage_bootloader...
08-09 13:24 DEBUG WindowsBackend: Copying C:\Users\User\AppData\Local\Temp\pyl2869.tmp\winboot -> E:\Linux64\Debian12_S001\winboot
08-09 13:24 DEBUG TaskList: ## Finished diskimage_bootloader
08-09 13:24 DEBUG TaskList: # Finished tasklist
08-09 13:24 INFO root: Almost finished installing
08-09 13:24 INFO WinuiPage: appname=wubi, localedir=C:\Users\User\AppData\Local\Temp\pyl2869.tmp\translations, languages=['en_US', 'en']
08-09 13:25 INFO root: Finished installation
08-09 13:25 INFO root: Rebooting
08-09 13:25 DEBUG TaskList: # Running tasklist...
08-09 13:25 DEBUG TaskList: ## Running reboot...
08-09 13:25 DEBUG TaskList: ## Finished reboot
08-09 13:25 DEBUG TaskList: # Finished tasklist
08-09 13:25 DEBUG root: application.quit
08-09 13:25 DEBUG WindowsFrontend: frontend.quit
08-09 13:25 DEBUG WindowsFrontend: frontend.on_quit
08-09 13:25 DEBUG root: application.on_quit
08-09 13:25 INFO root: sys.exit
Download failed at your side for some reason, maybe network connection has failed, see the message:
08-09 13:24 DEBUG downloader: download finished (read 31457280 bytes)The correct download size is 1118322668 bytes
Try it once again and check for download errors. You could also download the file manually https://sourceforge.net/projects/q4os/f … oop.img.xz and install it with "--dimagepath" switch as described above.
Finally solved problem. The new network adapter was dropping connection which corrupted download. Switching to old adapter made error go away and q4os boot normally, although still only on SATA drive. Thanks Q4OS Team for your help, couldn't have figured it out without you.
nvme specs
Intel(R) Chipset SATA/PCIe RST Premium Controller
SCSI\DiskNVMe____CT2000P5PSSD8___R403
