#1 2024-08-03 11:55
gandalf
Chromebook Lenovo, Q4OS installato audio non funzionante
Salve,
oggi ho installato Q4OS sul mio Chromebook ma non funziona audio nonostante mi dia volume e altoparlante a posto con periferica audio professional.
Accodo inxi se qualcuno mi può aiutare ringrazio in anticipo.. see you soon
System:
  Host: paolo-q4os Kernel: 6.1.0-23-amd64 arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.5 Distro: Q4OS 5.5.1-n1
Machine:
  Type: Laptop System: Google product: Treeya v: rev7
    serial: <superuser required>
  Mobo: Google model: Treeya v: rev7 serial: <superuser required>
    UEFI: coreboot v: MrChromebox-4.14 date: 07/25/2021
Battery:
  ID-1: BAT0 charge: 14.0 Wh (30.0%) condition: 46.6/47.2 Wh (98.8%)
    volts: 11.6 min: 11.5
CPU:
  Info: dual core model: AMD A4-9120C RADEON R4 5 COMPUTE CORES 2C+3G bits: 64
    type: MCP cache: L2: 2 MiB
  Speed (MHz): avg: 1193 min/max: 1200/1600 cores: 1: 1186 2: 1200
Graphics:
  Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] driver: amdgpu v: kernel
  Device-2: Luxvisions Innotech EasyCamera 1M type: USB driver: uvcvideo
  Device-3: Chicony Integrated Camera 5M type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: amdgpu
    unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
    resolution: 1366x768~60Hz
  API: OpenGL v: 4.5 Mesa 22.3.6 renderer: AMD Radeon R3 Graphics (stoney
    LLVM 15.0.6 DRM 3.49 6.1.0-23-amd64)
Audio:
  Device-1: AMD driver: snd_hda_intel
  API: ALSA v: k6.1.0-23-amd64 status: kernel-api
  Server-1: PipeWire v: 0.3.65 status: active
Network:
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    driver: ath10k_pci
  IF: wlp1s0 state: up mac: d8:f3:bc:d9:ab:89
Bluetooth:
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
  Report: hciconfig ID: hci0 state: up address: D8:F3:BC:D9:AB:8A bt-v: 2.1
Drives:
  Local Storage: total: 29.12 GiB used: 8.17 GiB (28.1%)
  ID-1: /dev/mmcblk1 model: MMC32G size: 29.12 GiB
Partition:
  ID-1: / size: 20.03 GiB used: 8.09 GiB (40.4%) fs: ext4 dev: /dev/mmcblk1p2
  ID-2: /boot/efi size: 299.4 MiB used: 5.8 MiB (2.0%) fs: vfat
    dev: /dev/mmcblk1p1
Swap:
  ID-1: swap-1 type: partition size: 8.3 GiB used: 73.5 MiB (0.9%)
    dev: /dev/mmcblk1p3
Sensors:
  System Temperatures: cpu: 35.5 C mobo: N/A gpu: amdgpu temp: 35.0 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 220 Uptime: 29m Memory: 3.77 GiB used: 3 GiB (79.5%) Shell: Bash
  inxi: 3.3.26
