What settings can I modify in Q4OS (Trinity desktop) for the absolute lightest and smoothest experience? How do I make it as streamlined and no-frill as possible?
I'm just a hobbyist reviving an old laptop (Dell XPS M140). I've already updated to an SSD, 2 GB of RAM (maxxed for my device), and a bunch of other small hardware improvements. It runs pretty well but can still be a little stodgy at times. Thank you for your thoughts! The device is just for light office and sheet music writing.
What Desktop environment are you using ? If it's for an old computer, I presume it's Trinity DE ? If it's the case, you can try my 'performance script'; you can found this here: https://github.com/seb3773/q4osXpack . There are 'classic' optimizations done by the script, and some other a little more 'exotic', but nothing that will put the stability/reliability at risk. (I'm using this on some very old laptops to help them run as smoothly as possible)
Besides that, there are some threads that deals with this, for example: https://www.q4os.org/forum/viewtopic.php?id=4430
Install an SSD in your laptop, get some cheap 120/128GB one and it will make the machine as fast as possible.
Q4OS running on IBM ThinkPad T60 - C2D T7200, 3GB RAM, 128GB SSD / pockethacks.com / jdmedmparts.com
I’ll give it a shot! I’m using Trinity. How do I install/use the script? I’m a complete noob.
Well, it's relatively easy. The scripts are hosted on github, so you will need to install 'git', you can do this from a terminal:
sudo apt install gitThen, you can can 'clone' the repository by doing:
git clone https://github.com/seb3773/q4osXpackOnce done, go the directory q4osXpack:
cd q4osXpackYou'll have to set the main menu script executable:
sudo chmod +x qxpackAnd finally launch the main menu script:
./qxpackDebian & Q4OS (TDE!!), low-level C, ASM (z80/68k/x86/ARM64), embedded systems, CPU architectures (RISC-V, binary formats, assembly), retro-computing, metal music, guitar and sci-fi.
shingi345 wrote:I’ll give it a shot! I’m using Trinity. How do I install/use the script? I’m a complete noob.
./qxpack
Very easy! I did the performance optimization ones. Some were automatically highlighted and others weren’t. Any more I could or should do? Thank you for the help
Not so much, you have to take into account that Q4OS is already very well optimized. Besides what my script can do, I can't think of anything else (at least anything that will not put stability at risk) to improve performance. You can try a custom kernel (not selected by default in the perf script); it can help a little bit.
shingi345 wrote:Any more I could or should do? Thank you for the help
Hi, I really hate the fact this script uses zram instead of zswap. I forgot to uncheck it and now cannot revert back to my og grub defaults.
freaky
Yeah, not everyone want zram, that's exactly why you can disable the option
But this part of the script doesn't do any modification to your grub config, if you want to remove zram you just have to do:
sudo apt remove zram-tools
you may have to re-enable dphys-swapfile if you want, and re-create a swap file if needed.
Raintania wrote:Hi, I really hate the fact this script uses zram instead of zswap. I forgot to uncheck it and now cannot revert back to my og grub defaults.
You're a legend! Thanks mate.
freaky
