#1 2024-06-22 15:18
nicholasp
Q4OS 32 bit - spotify
Hi, I try to install the Spotily Client but I have dependencies issues.
Any suggestions ?
The following information may help to resolve the situation:
spotify-client : Depends: libcurl3 but it is not installable
Depends: libssl1.1 but it is not installable or
libssl1.0.1 but it is not installable or
libssl1.0.0 but it is not installable
Recommends: libavcodec-ffmpeg56 but it is not installable or
libavcodec-ffmpeg-extra56 but it is not installable or
libavcodec54 but it is not installable or
libavcodec-extra-54 but it is not installable
Recommends: libavformat-ffmpeg56 but it is not installable or
libavformat54 but it is not installable
E: Unable to correct problems, you have held broken packages.
#2 2024-06-22 18:42
Re: Q4OS 32 bit - spotify
There is no 32bits version of Spotify for linux. (dependencies can't be satisfied on 32bits os). You'll have to use the web player instead.
#3 2024-06-22 23:52
nicholasp
Thanks for the answer. After too much search I've found the solution. There is an unofficial client called spotify-qt. It is easy to install it with snaps:
sudo apt update
sudo apt install snapd
sudo snap install core
sudo snap install spotify-qt
You have to restart your machine to see the new app in the menu.
#4 2024-06-23 15:34
Thank you very much for the tip ! I will test it as soon as possible (I'm a spotify user too tongue) ; I noticed there's an appimage version of this app:
https://github.com/kraxarn/spotify-qt/r … 1.AppImage
If it works with 32bits, I suggest to use it instead of installing the *infamous* snapd (I really dislike snap... It's not the place to explain why, but I prefer Appimage).
I see we can build the binary too, I think I will try to build a package from it smile
#5 2024-06-24 10:37
Here it is:
https://github.com/seb3773/spotify-qt-spotifyd-packages
x64, i386 & armhf packages.
(you have to install spotifyd too, as it is needed by spotify-qt to play music on your local machine).
It's lighter than the snap/appimage versions and should start faster too smile
