#1 2024-06-08 23:36
DNS configuration for NetworkManager
Hello,
Which DNS does Q4-4.12-TDE use; how can i check it?
i read here, that the networkmanager should save the settings in /etc/NetworkManager/system-connections/<name-of-connection> but the folder ist empty.
And, when i right-click on the tde-nm icon in the taskbar, and select "edit connection", choose my connection, check "Use manual IP-Connection, add a DNS, and save it... i see it's not saved the next time i edit it.
Thanks in advance
#2 2024-06-09 09:54
Re: DNS configuration for NetworkManager
$ nmcli connection show <connection_name>
FlexQ4 wrote:
... the networkmanager should save the settings in /etc/NetworkManager/system-connections/<name-of-connection> but the folder ist empty.
It's valid for wireless connections only.
We will check that. Anyway, you need to use manual IP address along with manual DNS.
