Using (trying as a newly installed system) 32-bit Trinity Aquarius. I have script file Test.sh as
#!/bin/sh
echo "testing..."
sleep 10
From the terminal line (Konsole) it can successfully run using
dlrider@q4os-desktop:~/apps$ ./Test.sh
But from file manager Konqueror, it only opens in the configured text file editors, currently default now is Geany. I have set the file as executable (chmod +x). I have added to the .sh file association, Konsole to use as top preference, for the application type x-shellscript.
If I ditch Konqueror as the file manager, and add trinity-dolphin (I believe), will everything smooth out? I won't break anything?
#!/bin/sh echo "testing..." sleep 10
Installing doplhin trinity won't change this. I believe it is much better to not have scripts executed when you double click on it (safer in a way). Although this can be achieved, may I suggest you instead using some services menus ?
I joined a zip file with two .desktop files (you have to put them in "~/.trinity/share/apps/konqueror/servicemenus/" (and in "~/.trinity/share/apps/d3lphin/servicemenus/ if you use dolphin trinity), and two .sh files, just put them in "/usr/local/bin/", and set them executable.
Once this done, you'll have two new entries when you right click on a .sh file on the desktop or in konqueror/dolphin file manager: execute script / execute script as root. These scripts will open konsole and execute your script accordingly.
Tell me if it works for you
My Q4OS scripts: win10/osx theming, perfs optimisation, laptop configuration, ... for trinity users --> https://github.com/seb3773/q4osXpack
